Old 08-21-2016, 10:24 PM   #1
waltere
Default Engine temp fluctuates HELP
I got about 100 miles on my 8ba flat motor. It acts unpredictable. It can idol and temp stays at 185 on a 95 degree day. Drive down the road 2200 rpm stays @185. after about 10 miles same rpm climbs to 195 - 205 and fluctuates. every thing is new and belts are correctly tightened. Ideas?
waltere is offline   Reply With Quote
Old 08-21-2016, 10:27 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Engine temp fluctuates HELP
Bad sending unit.
Old 08-21-2016, 10:31 PM   #3
waltere
Mechanical gauge Is that possible? Its an old AC gauge that I had rebuilt
Old 08-22-2016, 07:37 AM   #4
JSeery
JSeery's Avatar
Couple of fairly easy checks would be a handheld IR thermostat or try a different gauge. Might also check if it is both sides or just one while your at it.
