02-23-2022, 11:33 AM | #41 |
Re: NAPA CS30 Points
Did the rubbing block wear down because of poor material or because of the cam having a rough surface?
In my case I had installed a new, replacement "B" cam (from a reputable supplier) because I was led to believe that the "B" cam had a better profile and would produce longer dwell time. Assuming that the cam was as smooth as it should be I never thought to check the surface of it, just installed it, set the points gap and the timing. When the points rubbing block wore down in a relatively short time was when I discovered that the cam surface was quite rough and needed polishing to make it serviceable. YMMV
02-23-2022, 04:08 PM | #42 |
One option is to eliminate the points altogether. There are electronic points available for the Model A starting at about $80. Not for the purist. You have to run a bunch of more wires. I tried this on my Model T and eventually took them off. You have to have a hot coil to have them work and they will not fire if the battery is low, so no hand cranking with a weak battery. But they don't need adjustment and will last a long long time.
02-23-2022, 06:33 PM | #43 |
katy,
The only thing I can come up with is the rubbing block must be made out of a poor material. My cam, which is also a "B" cam, is nice and smooth. The points that I took off, still have a very nice rubbing block on them and they have at least 1400 miles of use. I ended up putting them back on the car. That is why I am looking for a picture of original 30's points to see if that is what they are. nkaminar, Thanks for the thought, but I am one of those people who like things to remain original if at all possible. I also have a Model T still running the buzz boxes.
Tom L. |
02-23-2022, 08:58 PM | #44 |
The points on my 1930 Model A, which I bought in 1960, were original Ford and lasted until I sold the car in 1967. I put many thousands of miles on the car and never changed the points or condensor. I am wondering if one could machine (or carve) a rubbing block out of Delrin to replace what is in the repo points. Delrin is a hard plastic but has Teflon in it so the friction coefficient is very low and it has good wear resistance. It will take the temperature in the distributor. It is good for 250 F.
That brings up the question of how hot is it in Dirtrack's distributor and whether that is a factor.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 02-24-2022 at 11:40 AM. |
02-23-2022, 09:21 PM | #45 | |
Neil, I been wondering if a hard maple rub block could be used. I think, there were bearings made of it and used in combines fairly recently???
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
02-23-2022, 11:23 PM | #46 |
i couldn/t get a good photo so you have to squint.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
02-24-2022, 10:52 AM | #47 | ||
I made the rubbing block out of some 1/2" fibre board I had, similar to the original material.
02-24-2022, 11:04 AM | #48 |
check out post #23 from KATY
02-24-2022, 11:14 AM | #49 |
I just cleaned up and installed a set of original Ford points in a distributor I'm restoring.
02-24-2022, 11:18 AM | #50 |
I assume those points were made by an outside supplier for Ford, I see the Ford script, what company does the other symbol represent?
02-24-2022, 11:28 AM | #51 | |
02-24-2022, 11:38 AM | #52 | |
Thanks to Bob B for the chart
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 02-25-2022 at 10:45 AM. Reason: Correction |
02-24-2022, 11:38 AM | #53 |
McMaster Carr has tons of different rivets and the tools to set them. The hollow rivets start at .156 diameter but one could make hollow rivets out of other types by drilling out the end.
02-24-2022, 11:47 AM | #54 |
02-24-2022, 12:07 PM | #55 |
In the picture Old Ugly posted in #46 it mentions the trademarks along with the Ford script but does not say if they are Ford trademarks or an other manufacturer trademarks.
02-24-2022, 12:27 PM | #56 |
katy, ndnchf,
That is what I needed to know. The points that I just put back in do not have those markings. I can not find any marks on them at all. They appear to have a plastic rubbing block. The Napa CS30 points are pictured below. The block lasted 612 miles.
Tom L. |
