Old 08-05-2021, 02:56 PM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Inner tube advice needed
Do any of the suppliers sell a heavy-duty 21 inch inner tube? I patched, installed, re-patched, installed my older one....another leak! Gave up. Got my new one installed today......new leak. Patched, installed.....still leaked around my new patch after I made sure it didn't leak before I put it in. I was careful to not pinch the tube while remounting the tire. I have had no leaks in the four tires on the car, and they have been holding air just fine for at least 21 years!
walkerlakeprinter is offline   Reply With Quote
Old 08-05-2021, 03:18 PM   #2
ModelAMike1930
ModelAMike1930's Avatar
Default Re: Inner tube advice needed
Try ebay and next time use talcum powder on the tube to make sure it slides in easier.
ModelAMike1930 is offline   Reply With Quote
Old 08-05-2021, 03:32 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Brattons was the manufacturer of the best inner tubes. Check with them?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-05-2021, 03:38 PM   #4
alexiskai
alexiskai's Avatar
I got five 21" tubes from Lucas back in June, they held up fine.
Old 08-05-2021, 04:40 PM   #5
J Franklin
J Franklin's Avatar
What was causing the air to escape? You left the most important fact out. Maybe you need to let a tire store patch and install the tube for you.
J Franklin is online now   Reply With Quote
Old 08-05-2021, 04:56 PM   #6
walkerlakeprinter
Little tiny holes on the inner part, next to the rubber stem. I need to pick up some new patches and cement and try again. When I go to town tomorrow, I will ask the guys at the tire store....maybe they have some vulcanizing patches they can install next time.
Thanks for the advice.
Old 08-05-2021, 05:09 PM   #7
Tom Endy
Tom Endy's Avatar
We had a tire go flat on my grandson's 30 Tudor. The tires and tubes are new, installed a few months ago and only on the road a few days ago. A few trips around the block and the tire went flat. We found a pin hole in the side of the tube. It was not caused by a pinch. We were careful to use baby powder and not force it with tools. We patched the tube and so far it is holding. Inner tubes are suspect today because they are not normally made for cars anymore, just bikes and motorcycles and we all know where they come from.
Tom Endy
Old 08-05-2021, 05:19 PM   #8
walkerlakeprinter
My old one was made in China. My newest one was made in Vietnam. I'm going to order one from Brattons and hope theirs is better.
Old 08-05-2021, 06:45 PM   #9
The Master Cylinder
The Master Cylinder's Avatar
I gotta ask, did you check the inside of the tire? Maybe something is poking your tube.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-05-2021, 07:01 PM   #10
TerryH
TerryH's Avatar
I bought 5 new inner tubes from Bratton’s earlier this year……4 of the 5 have slow leaks in them…..have to air up some every few weeks.
TerryH is offline   Reply With Quote
Old 08-05-2021, 07:19 PM   #11
chrs1961815
chrs1961815's Avatar
A little bit over a year ago I put new tires on newly restored 21 inch wheels and I have had no issues, no leaks. They were bought from Kelsey Tires and are the firestone type. Came with inner tubes.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-05-2021, 07:28 PM   #12
updraught
updraught's Avatar
Sometimes there are bad batches of values that do that.
updraught is offline   Reply With Quote
Old 08-05-2021, 08:52 PM   #13
walkerlakeprinter
To the Master Cylinder: all the holes in the tubes showed up on the part where they touch the rim liners which are perfectly smooth.
Old 08-06-2021, 07:10 AM   #14
chap52
chap52's Avatar
A couple of years ago I bought a new tube from Brattons. It had a small leak near the stem right out of the box. I called them and they sent out a new tube that day. I was told that this was an recurring issue with their latest batch? Should have a new batch in stock since then.
So my frustration with the adventure now causes me to always put air in a new tube and sink it in some water to check for leaks before putting it on the car. Chap
Old 08-06-2021, 09:45 AM   #15
arnhemmer
I bought tires and tubes from Mike's A Fordable about 5 yrs ago and have very good luck with the tubes. No air loss to speak of. What is the consensus as to how long I should keep them. I'm in the need of tires very shortly. Should I use the same tubes with the new tires?
arnhemmer is offline   Reply With Quote
Old 08-06-2021, 11:40 AM   #16
Patrick L.
Patrick L.'s Avatar
I was going to suggest using rim liners, but, apparently that isn't, or maybe it is, the problem with yours.
There are, as said, a lot of junk tubes out there. Motorcycle tubes were being awhile back.
Old 08-06-2021, 08:18 PM   #17
updraught
updraught's Avatar
Hard to say. Some will last, some won't. Depends what they are made of. Some will fall to pieces before you can use them, a bit like a plastic shopping bag left in the sun.
The Coker ones for radials are very heavy and very expensive. You would hope they will last.
Old 08-06-2021, 10:25 PM   #18
arnhemmer
These can also be used with radials. Maybe I'll look at them to see what shape they are in when I'm ready for new tires. With no air loss accept for the monthly pressure check, they are performing very well. Thanks for the reply.
Old 08-06-2021, 11:25 PM   #19
J Franklin
J Franklin's Avatar
I use old good tubes until they don't work any longer.
Old 08-07-2021, 12:00 AM   #20
Harpkatt
Harpkatt's Avatar
This is exactly what I was thinking. I was a bike mechanic for years and a lot of times a customer repaired tube had something in the tire or tube that was causing the problem. If the holes keep popping up in the same area its a likely cause. Or your overstretching the tire somehow, maybe its the wrong size.
Harpkatt is offline   Reply With Quote
