08-05-2019, 03:48 PM | #1 |
Distributor fittings
Anyone know the port sizes for the dual vacuum distributor?
08-05-2019, 07:43 PM | #2 |
Re: Distributor fittings
The fitting(s) should be 3/8" - 24
This is a 56 DUAL DIAPHRAGM LOAD-O-MATIC?
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
08-05-2019, 08:00 PM | #3 |
Yotehunter66, example photos...
08-06-2019, 10:10 AM | #4 |
I believe they are two different sizes. The inner diaphragm for the line from the front of the carb should be 3/8-24. Not sure about the outer one for manifold vacuum. I think it's for an inverted flare fitting (size ?).
Sal |
08-06-2019, 01:15 PM | #5 |
the outside one is larger but i dont know the sizes
08-06-2019, 05:48 PM | #6 |
08-06-2019, 06:52 PM | #7 |
Will you be re-using the original '56 4bbl carburetor?
Should I assume you need replacements for missing or damaged metal vacuum lines??? You can contact any of the several T-Bird restoration parts suppliers, their catalogs can be very helpful. They have reproduction replacements and some may have good used oem parts if you prefer. It is often more effective to contact their parts departments in person on the phone. part # 12370 ('56) https://www.classictbird.com/ https://hillsresto.com/ https://www.larrystbird.com/1955-195...bird-products/ . Last edited by dmsfrr; 08-10-2019 at 09:33 AM. |
08-10-2019, 01:55 AM | #8 |
I didn't see your reply ... The secondary line is 1/4" -8 pipe thread. The actual lines are available repro. Sorry About That ...
