03-22-2019, 01:26 PM | #1 |
1952 f1 no gage lights
So I lost my gage lights today,so I am trying to trace things down,does anybody have the wiring for the headlight switch?
03-22-2019, 01:42 PM | #2 |
Re: 1952 f1 no gage lights
This help?
Thanks Andy 1952 F1 |
03-22-2019, 01:53 PM | #3 |
As Andy’s diagram indicates the gauge lights are on a rheostat. If they worked previously it could be as simple as the light switch knob has been accidentally rotated to the extreme right.
Hope this helps, Tom |
03-22-2019, 03:17 PM | #4 |
are not the gauge lights on a switch mounted under dash to left of steering column
03-22-2019, 04:12 PM | #5 |
03-22-2019, 04:12 PM | #6 |
03-22-2019, 04:43 PM | #7 |
This is true for the 48-50 models.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-22-2019, 08:12 PM | #8 |
I have a 49 so this is how mine are, just did not know when the change occurred. Hey my lights work just fine
03-24-2019, 01:34 PM | #9 |
So I checked today and I have no power to the switch ,terminal of the rheostat for dash lights,now where do I trace down?
03-24-2019, 04:44 PM | #10 |
The power comes from the CB panel. There are two CBs, both go to the Light Control Switch. One is for the headlight circuit and the other is for the Instrument Lights amount other things. First I would check and see if the other lights on the Light Control SW work, or just check the power coming into the Light SW. This is a 50 and earlier diagram, but the later F1 is the same except for the addition of the dimmer on the Light Control Switch.
03-24-2019, 05:50 PM | #11 |
Circuit protection will usually auto reset unless it's wore out. A wire or terminal could be open or loose. The rheostat in the light switch can also be problematic but they will usually be intermittent until they die completely.
03-24-2019, 08:33 PM | #12 |
I was leaning on checking the circuit breakers,what is a good way to checking!!
03-24-2019, 08:36 PM | #13 |
Bypass the rheostat to see if that is the problem
03-24-2019, 08:37 PM | #14 |
Bypass the rheostat with a temp jumper wire to see if that is the problem wit
03-24-2019, 09:10 PM | #15 |
03-25-2019, 08:48 AM | #16 |
If you jump a circuit that is suspect of a short, a fuse should be incorporated into the jumper or it might burn you. I've seen wires burn before and they can go completely within 2 seconds.
03-25-2019, 11:20 AM | #17 | |
If no voltage as said above the rehostat is open/defective. Hope this helps, Tom |
