Old 07-20-2018, 03:18 PM   #1
braol
braol's Avatar
Default Question about flushness of doors...
Hello! I've posted below about my new Model A ('31 Tudor). One nagging question: car is straight, no rust, looks even all around but...the back edge of both doors do not sit 100% flush with the body...like they are not shut all the way...not a ridiculous amount, but enough to be noticeable. The gap is even all the way up the door and the passenger side is ever so slightly less flush than the other. First thought is sagging frame, but if that were so the door gap would get progressively narrower at the top. The amount of protrusion is also even from bottom to top, so it's not a frame twist issue.
Is there a way to 'tighten-up' the door closure so that the doors sit flush to the body?
"I have not yet begun to defile myself."
-Doc Holliday
'31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex
braol is offline   Reply With Quote
Old 07-20-2018, 03:31 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Question about flushness of doors...
If you slowly close the door do you feel any type of bind? If not you might get lucky by adjusting the striker/latch mechanism. Sounds like it may be worn a bit.
Tacoma Bob is offline   Reply With Quote
Old 07-20-2018, 04:39 PM   #3
Bob C
The doors overlap the body in the back.
Bob
Old 07-20-2018, 04:47 PM   #4
woofa.express
woofa.express's Avatar
yeh, "me to". marginal but irritating. I'll watch for the responders, cheers, gary.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 07-20-2018, 04:48 PM   #5
Vin-tin
Vin-tin's Avatar
Yeah what Bob said. They aren't suppose to be flush like a modern car.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 07-20-2018, 05:31 PM   #6
Oldbluoval
Oldbluoval's Avatar
Later on they were "aircraft" doors; not overlapping the jamb pillar
If they are out all way up, Tacoma Bob has a point in binding.
Post some pics if you can
There is some adjustment in the striker that might draw the whole door in a bit
Oldbluoval is offline   Reply With Quote
Old 07-20-2018, 06:16 PM   #7
Synchro909
Synchro909's Avatar
I don't know how many times well meaning people have told me that the door isn't closed properly and look thoroughly confused when I say they are supposed to be that way. They didn't make cars the same way 90 years ago as they do now.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-21-2018, 08:02 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
With a flat file, sharpen the "teeth" on the striker plates, helps them "bite" into the door latch, better.
Bill Sharp
"THE ASSISTANT GURU OF STUFF"
Old 07-24-2018, 09:46 AM   #9
braol
braol's Avatar
The sprung metal piece that "opens" when you turn the handle is worn where it rests on the body mounted striker plate. I will post a photo this afternoon or tomorrow.
-Doc Holliday
Old 07-24-2018, 09:53 AM   #10
Tacoma Bob
Tacoma Bob's Avatar
If you can get the striker loosened up a bit to adjust, that may be all you need.
Old 07-24-2018, 11:50 AM   #11
braol
braol's Avatar
Strykers are at max adjustment.
-Doc Holliday
Old 07-24-2018, 12:04 PM   #12
Tacoma Bob
Tacoma Bob's Avatar
Latch needs some attention. Perhaps remove and build up with by welding then file down.
Old 07-24-2018, 01:00 PM   #13
old31
To me the picture of the door looks perfectly fine. Normal.
Old 07-24-2018, 02:26 PM   #14
Oldbluoval
Oldbluoval's Avatar
Agree with old31
Old 07-24-2018, 02:29 PM   #15
Dennis Pereira
Dennis Pereira's Avatar
It must be the heat what pictures .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 07-24-2018, 03:22 PM   #16
DD931
DD931's Avatar
Tudor doors overlap. They're built that way and are not designed to be flush.
DD931 is offline   Reply With Quote
Old 07-24-2018, 03:58 PM   #17
Synchro909
Synchro909's Avatar
It's cold here but I agree, what pictures!?
