Old 06-24-2016, 06:57 PM   #1
Wick
Wick's Avatar
Default 41 won't start when hot
My 41 tonner,carb problems fixed. New external coil,wires,plugs. Old points,but I cleaned them and adjusted on krw fixture. Truck turns over one time and fires right up,drives smooth and pulls thru the gears nicely. After a 5 mile drive,let sit 10min. Won't start. Hit the electric fuel pump....still won't start. Wait 30min a few cylinders will fire then it picks up and runs.
Could this be the old points or point spring tension causing this?
Wick is offline   Reply With Quote
Old 06-24-2016, 07:04 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: 41 won't start when hot
Bad coil or bad condenser. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 06-24-2016, 07:21 PM   #3
alanwoodieman
leaking power valve? next time stick your nose into the carb and see if it flooding- we have that problem around the south if you even think about touching the gas pedal before you crank over a hot engine
alanwoodieman is offline   Reply With Quote
Old 06-25-2016, 10:18 AM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Wink Re: 41 won't start when hot
condensor ............
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 06-25-2016, 10:26 AM   #5
41panelmark
41panelmark's Avatar
Condensor for sure.
41panelmark is offline   Reply With Quote
Old 06-26-2016, 07:26 PM   #6
Wick
Wick's Avatar
The condenser came with the modern coil style kit. I replaced the coil with a new one and it stars better now.
I'll change the condenser just it case. Will do another test run tomorrow.
Thanks
Old 06-27-2016, 12:49 AM   #7
ABento
I'm having a similar problem and was just going to post the question of a carb spacer, mine won't start when how and when it does it seemed flooded,tonight I looke dat the carb and the bottom of it and the manifold are wet, I fired it up and let it run for several minutes and could here the carb gurgling and gas boiling out,I'm guessing this oen needs a phonolic spacer, is there such a thing on these.
ABento is offline   Reply With Quote
Old 06-27-2016, 06:45 AM   #8
Terry,OH
Terry,OH's Avatar
ABento: Yes, there are spacers check out V8 Times ad for Robert Shewman or send him an email [email protected] You most likely have a carb problem. If you are using the Ford Holley 94 check out the power valve and it's gasket, the fuel input valve, the fuel pressure (<2.5#). Charlie Schwendler is the 94 repair person He also has an ad in V8 Times Services section.
Old 06-27-2016, 10:48 AM   #9
ABento
This has got the 50 series carb on it.
After thinking about this some more my guess would be that its getting hot and boiling the gas,which is seeping to the outside of the carb,but bubbling into the intake manifold as well,this is my hard starting problem as it is flooded and hot gas is less likely to fire, I'll get the phomlic spacer and see how that works.
Thank you
Old 01-18-2020, 09:21 PM   #10
[email protected]
bad condensor
jhljr44@yahoo.com is offline   Reply With Quote
Old 01-18-2020, 09:22 PM   #11
[email protected]
Mine did the same thing and it was the condenser.
Old 01-19-2020, 02:53 PM   #12
drolston
drolston's Avatar
Had the same problem. Mine was the coil. Step one: Check the spark when cranking the hot engine. Should get a nice blue spark to jump half an inch. Good spark but no start, - then look at carb flooding.
Old 01-19-2020, 03:03 PM   #13
Tinker
Tinker's Avatar
Hey Guys this thread is like 3 1/2 yrs old. I hope he fixed it.
Old 01-19-2020, 03:10 PM   #14
grumppyoldman
grumppyoldman's Avatar
I had the same problem with my car, I'm supprised someone didn't mention the connections on the ballast resistor, they need to be clean and tight. After I got mine cleaned the engine fired up, the corrosion causes a low voltage to the coil. Check it out, its located under the dash where the resistor and fuse box is. Hope this helps your problem. Al
grumppyoldman is offline   Reply With Quote
Old 01-19-2020, 06:15 PM   #15
tubman
tubman's Avatar
He either fixed it or quit.
