10-10-2016, 11:07 AM | #1 |
Zenith Carburetors
I think that I know that the carbs that have the designation Zenith-1 are the original Zenith produced carburetors and those marked Zenith-2 are the Holly produced carbs made when Zenith could not keep up.
My question is, is either one more valuable than the other? I need to decide which I use as a body to give to get a good rebuilt one, and which I keep for the future. |
10-10-2016, 12:31 PM | #2 |
Re: Zenith Carburetors
pm sent.
10-10-2016, 01:00 PM | #3 |
It all depends on if you are doing a points car or driver which one you use or if the ones you have are correct for your year and month if you are doing a points car. The only ones that might have more value would be the side bowl or Zenith 3.
10-10-2016, 01:58 PM | #4 |
Over the years many Zenith carburetors found their way to a rebuild facility where the top and bottom castings were separated and became mismatched. Quite often you will find a Zenith top mated with a Holly bottom or vise-versa.
A Zenith-1 may be only half a Zenith and a Zenith-2 may be only half a Holly. Tom Endy |
10-13-2016, 02:58 PM | #5 |
What was the out come?
10-13-2016, 04:08 PM | #6 |
10-13-2016, 06:00 PM | #7 |
I have the same adjustable main jet thing. It was on a stationary engine zenith.
internals are interchangable. Bob |
