08-28-2017, 12:55 AM | #1 |
stromberg 97 setup
Does anyone know what size jets and power valve I should be running on a dual carb set up. There going on a 59ab with a 4" crank and isky max 1 cam. They will be installed on a thickstun pm7 high rise manifold.
08-28-2017, 02:01 AM | #2 |
Re: stromberg 97 setup
I have 43 main jets and 67 powervalves in mine and it seems to work. 59ab, max 1 cam, Navarro dog bone manifold.
08-28-2017, 06:58 PM | #3 | |
I am running the exact same in my 59a with slingshot intake in Michigan sea level and it runs real well. My friend with an H&H flathead was running the same here in Michigan and it worked well for him too. Good luck! Matt
1932 2 door sedan/ Merc Flathead 1932 5W 1932 Roadster/ SCoT Flathead 1932 Roadster Cadillac power |
08-28-2017, 11:40 AM | #4 |
If you drive in an area under 5,000 feet elevation, you should probably start with the stock .045 jets and 65 power valve. Drive it a while and check the color of the plugs. Browish is good. Blackish may be running a bit rich and you might try the .043 jets. Dusty white might indicate a bit too lean, and go up a jet size.
08-28-2017, 05:13 PM | #5 |
I have dual 97s and had used 43 main and 65 pvs at 600 ft above sea level. Ran lean. Went to 45 mains and 71 pvs and runs very well. Use 45 mains and 65 pvs and engine would bog - to much gas. You might want to consider model 48 strombergs.
08-28-2017, 07:40 PM | #6 |
08-30-2017, 09:14 PM | #7 |
Ok, well.... sea level-ish 😜. More so than Denver at least....
