Old 07-14-2017, 03:09 PM   #1
Rob Needs
Rob Needs's Avatar
Default Can't lock rear wheel up on adjuster.
I thought i would give the brakes a once over today,I did it by the book and made the brake board.
But I can't get the rear passenger side to lock up when I have the board on the third notch, its tight but not locked. I can't lock the wheel up on the brake adjuster even without using the brake board.
The brakes aren't that old.
Rob Needs is offline   Reply With Quote
Old 07-14-2017, 03:17 PM   #2
JOHN CT
JOHN CT's Avatar
Default Re: Can't lock rear wheel up on adjuster.
Wheel bearing grease or rear end oil on the shoes? I would pull the drum and check things out. It should lock up.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 07-14-2017, 03:20 PM   #3
1955cj5
1955cj5's Avatar
I would also measure the individual brake rods clevis pin to clevis pin, and compare the left to the right..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 07-14-2017, 03:21 PM   #4
SeaSlugs
SeaSlugs's Avatar
can you turn the adjuster all the way in and lock the wheel? if not you got some major issues in the drum area.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-14-2017, 03:29 PM   #5
Joe K
Joe K's Avatar
Could be worn shoes, worn (oversize) drum, length of connector rods, sheared pin in the lever/clevis area, even worn cam - although this is less likely. A stuck cam could do it - you bear down on one shoe only and this still not enough to make the drums "self energize" (which they don't on the Model A but you need that "double push" to maximize your brake shoe pressure.)
Joe K
Shudda kept the horse.
Old 07-14-2017, 03:31 PM   #6
Patrick L.
Patrick L.'s Avatar
I agree there seems to be an issue with the adjuster wedge or the backing plate.
Disconnect the pull rod and see if you can then get the adjuster to lock the wheel. That will give an indication where the problem is.
