Old 02-01-2023, 07:30 PM   #1
Krylon32
Default Flathead A Roadster
I know this is a FH V8 restorers forum but there's a Flathead A Highboy roadster on Pew's Place and on a thread I started on the HAMB that deserves a good look. It has the look. Sorry if this thread offends some of you, I go both ways, restored or modified cars are all welcome in my garage.
Krylon32 is offline   Reply With Quote
Old 02-01-2023, 07:51 PM   #2
hotcoupe
hotcoupe's Avatar
Default Re: Flathead A Roadster
What is the title of the thread?
hotcoupe is offline   Reply With Quote
Old 02-01-2023, 08:21 PM   #3
TJ
TJ's Avatar
I thought Lynn Pew closed his website some time back?
Old 02-01-2023, 08:26 PM   #4
Krylon32
A Roadster On Pew's Place. Lynn still does a blog occasionally when he's able.
Old 02-01-2023, 09:59 PM   #5
hotcoupe
hotcoupe's Avatar
Here's the link (I hope)!https://www.jalopyjournal.com/forum/...#post-14755627
Old 02-01-2023, 10:19 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by hotcoupe View Post
THAT thing is RIGHTEOUS! I'd love to see how that front spring is tied-into each wishbone.
Coop
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 02-02-2023, 12:35 AM   #7
deuce_roadster
deuce_roadster's Avatar
How can the steering possibly work?
Old 02-02-2023, 01:31 AM   #8
Randy in ca
Randy in ca's Avatar
My thoughts also. Can't see a draglink anywhere - doesn't seem to be anything attached to the spindles other than the tie rod. Obviously we're missing something!!
Randy in ca is offline   Reply With Quote
Old 02-02-2023, 05:18 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
A couple more 'teaser' shots that I was able to find. First pic suggests POSSIBLY a drag link going to a "Y" connection on the TIE ROD?
Shock arms appear to be attached to ends of main spring leaf?
Coop
T5 W/TORQUE TUBE
Old 02-02-2023, 05:35 AM   #10
Mart
Mart's Avatar
Lots of creative thinking there to make that all work. Nicely done.
Old 02-04-2023, 09:42 AM   #11
GB SISSON
GB SISSON's Avatar
Stunning. Bordering on pornographic.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 02-04-2023, 09:04 PM   #12
Tim Ayers
Neat car.
Steering is a cross steer box. You can see the pitman arm in the one of the picts. Coop posted. Drag link goes under car to the pass side spindle. Two u-joints to get the alignment of the steering rod correct since the box seems to be mounted under the motor mount of the frame rail.
Old 02-04-2023, 09:19 PM   #13
Fredb_
Fredb_'s Avatar
Very cool looking roadster! Love it.
Fredb_ is offline   Reply With Quote
Old 02-04-2023, 09:36 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Tim Ayers View Post
Neat car.
Ah, ah, AH! Look again, Tim! You can see in the pic BELOW that only the tie rod goes to the RIGHT spindle. That's why I SUGGESTED above that the drag link must tie into the tie rod via some sort of "Y" fitting.
Coop
T5 W/TORQUE TUBE
Old 02-04-2023, 10:28 PM   #15
Krylon32
I did a tie rod like that with a tapered hole in the tie rod under the car when I built the custom chassis for the Green Hornet.
Old 02-04-2023, 10:59 PM   #16
GB SISSON
GB SISSON's Avatar
No expert on frame or steering geometry, but is that set up something like on my jailbar trucks? I've knocked them apart for kingpins and then put them back together, but it looks familiar. I really do love that roadster.
Old 02-04-2023, 10:59 PM   #17
Tim Ayers
Ah, I see said the blind man. You are correct
Old 02-05-2023, 10:00 AM   #18
deuce_roadster
A modified rack and pinion hooked to the tie rod? The U joints are hooked to something.
Is the stock steering box cut off the shaft and moved forward and hooked directly to the tie rod? HMMMMMM.
Old 02-05-2023, 10:16 AM   #19
Ol' Ron
Ol' Ron's Avatar
I believe this is a beautiful piece of workman ship. It's obvious the owner/builder loves his job. Something like this is not for everybody, but some people jump out of perfectly good airplanes, just for fun!!!
Gramps
Old 02-05-2023, 10:19 AM   #20
tubman
tubman's Avatar
Be careful if you decide to use Rack and Pinion steering. A local guy found a rack that fit his '47 Plymouth perfectly in a "rear-steer" position. The trouble was, it was from a "front-steer" car.
