Old 05-24-2019, 09:25 PM   #1
Red98
Default Thread size in head for heater/heat sensor
I'm placing an order for a Spal 16" fan from Summit and figured to order the switch at the same time since there's a 10% Memorial Day discount.
What is the thread size something or other NPT for the heater connection heat sensor?
Probably need another 'Y' as well?
Any suggestions I'm all ears.
Red98 is offline   Reply With Quote
Old 05-24-2019, 09:53 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Thread size in head for heater/heat sensor
It is 3/8 NPT on my 1940 and 42-8 heads.
Old 05-24-2019, 11:38 PM   #3
Gene1949
Gene1949's Avatar
You really want to have that senor monitor the bottom tank coolant temp. No point in running the fan if the radiator is rejecting the heat load without the fan.
Besides, if the sensor is in the engine it is reading what the thermostats are doing not what the radiator is doing.
Just my $0.02 cents.
Gene1949 is offline   Reply With Quote
Old 05-24-2019, 11:57 PM   #4
Red98
Thanks Gene, that makes more scentse than two.
