06-11-2021, 03:37 PM | #1 |
Spark plug for driver, not show car.
I'm in charge of repairs/driving a friend's 30 Model A Fordor. It is probably 99% stock, still 6V, was rebuilt in 60's or 70's. Has mohair upholstery.
The plugs are probably from last rebuild, rusty, and need replacing. I know on my 56 Farmall there are hot and cold range plugs. What about the A ? I have a feeling this is like asking if Blondes or Brunettes are better, but what plug do you recommend for a 30 Model A driver. I'm going to order based on your advice. Oh, what is the gap on them also? ET |
06-11-2021, 03:51 PM | #2 |
Re: Spark plug for driver, not show car.
You'll get a ton of different answers. I use Autolite 3076. They are midrange temp, available, and not overpriced. Tried Champion 518 and car didn't run as well. I have the Autolites gapped at .032-.033. Folks will tell you gap should be .035. See what runs best in your car.
06-11-2021, 04:16 PM | #3 |
It'll depend on what heat range the car will like.
I've run Autolite 3077 for decades, but, can no longer find them. I find that Champion in the 18 heat range run fine. 16 seems to be too cold. |
06-11-2021, 05:04 PM | #4 |
More importantly ...... What are you running now and how well are they doing? Pull the plugs and compare them to heat range charts, there maybe pictures here
06-11-2021, 06:03 PM | #5 |
I have used Champion W16, W18 and Autolites too. Not much difference for me but yours may vary. All good plugs.
"The more things change, the more they stay the same." |
06-12-2021, 12:06 AM | #6 | |
Thanks |
06-12-2021, 05:06 AM | #7 |
Have been using Champion W16’s for to long to remember. Gap at .035. I change plugs every five or six years, no matter the mileage. More for the look than anything else. Car runs better with new plugs and it is a cheap repair.
Aside from changing the oil and tire air pressure, plugs are easy fix. |
06-12-2021, 05:14 AM | #8 |
06-12-2021, 06:06 AM | #9 |
06-12-2021, 06:06 AM | #10 |
06-12-2021, 07:35 AM | #11 |
ask the owner how concerned he/she is about appearance.
my car is strictly a driver but I like the look of 3X plugs better than any replacements, so am willing to pay the premium price. a set will last for MANY years...... if the old plug electrodes are not eroded, they may clean up and work fine. I take my 3X plugs apart and wire wheel the metal base then coat with WD40 to slow down the rust. (used to use gun bluing but it did not hold up any longer so was not worth the hassle) check the gap and install with new washers......
our next Model A is out there in the unknown...... Last edited by Chris in WNC; 06-12-2021 at 07:40 AM. |
06-12-2021, 08:39 AM | #12 | |
06-12-2021, 09:27 AM | #13 |
I use autolite 3076 plugs gapped at .035 i think
got them at autozone $3 ea. |
06-12-2021, 09:56 AM | #14 |
-What's in it now?? How does it run with them??
I used W-18's. Paul in CT |
06-12-2021, 11:18 AM | #15 | |
Did you use copper pipe end caps ontop of the plugs? I thought my compartment was clean... you sir must be Mr. Clean |
06-12-2021, 12:06 PM | #16 |
I run Champion W18 plugs and I am happy with them. Reasonably priced and available. It gives the look of a 3X plug at a fraction of the price. You will need to order the brass tops as the standard plug top thread will not fit. Again, inexpensive and they look period correct.
06-12-2021, 02:55 PM | #17 |
You’ll likely only buy them once so buy Champion 3X. Look great and work great! Spend the money !
06-12-2021, 07:25 PM | #18 |
I've always used Motorcraft TT10 plugs and can't see why people pay so much for some of the others. One of my cars has done over 50,000 miles on the one set and I have no thoughts of replacing them.
06-12-2021, 07:59 PM | #19 |
06-12-2021, 08:59 PM | #20 |
Thanks for all the info. I found a set of Autolite 3076 in town for $2.23 each. They only had 4. One was black, the other 3 chromed...Sigh... good thing she isn't a show car.
I gapped them at .33, installed them, my does it purr pretty. |
