04-29-2020, 01:56 PM | #1 |
1935 Ford coupe window regulator
Hi guys I'm going crazy trying to figure out why I can't get my windows to work ,they regulator keeps coming off the channel, ami missing something? Is there something that goes from the triangle piece on the window channel to the regulator to hold it in place? Thank you, I don't know how to post the pic or I would of
04-29-2020, 03:04 PM | #2 |
Re: 1935 Ford coupe window regulator
Go to your ad and click "edit",then click "go advanced".Bring the page up and you will see manage attachments.Click on that.Then a window comes up where you can put in your pics.Put in your pics,click upload .After they load click close.Then click save.They should be there on your ad.
04-29-2020, 04:20 PM | #3 |
Thank you got the pic up
04-29-2020, 05:41 PM | #4 |
There is a roller stud that goes in the triangular piece. In the picture your regulator is rolled down and the glass channel is facing the wrong way.
When the window is wound up the slot in the regulator "picks up" the roller stud which follows the slot until the window is up at which point the roller stud is pushed forward closing the "smoker" vent. Lowering operation is the opposite, slides back, then down. There is also a stop screw on one of the regulator gears to limit travel. |
04-29-2020, 06:07 PM | #5 |
