01-30-2016, 03:32 AM | #1 |
1947 Car trans
My '47 car finally gave up 1st gear, it was missing at least a tooth and making noises for years. I'm going to replace the trans or fix the old trans but have some questions. First time rebuilding an early trans so please bear with me.
1. I have a '40 car trans, could I use that or is the '47 better. 2. What internal parts (bearing/synchros) and seals are the best to use and from what vendor. 3. Is there any upgrades to do to make it work better or use more modern fluids (running GL4 now). 4. Which clutch disc/TO bearing is best, I've read it's better to get the stock cover rebuilt. I'm sure there will be more questions when I start. I also ordered the Mac Van Pelt trans book. I just want it to work good, not have to take it apart again and I have a distrust of repo parts. Last edited by 1oldtimer; 01-30-2016 at 05:12 AM. |
01-30-2016, 05:04 AM | #2 |
Re: 1947 Car trans
The 40 and 47 transmissions are the same, except for possibly a difference in the detail design of the synchro slippers and balls etc.
There is no reason the 40 trans could not be used if in good condition, again with one caution point. Do a tooth count on the gears. If the 40 has a 16/28 gearset and the 47 a 15/29 you might notice a difference when pulling away with the taller 1st gear. You should be able to mix and match parts from the two to get 'er up and running again, with the point about detail synchro design taken into consideration. Mac Van Pelts book would be very useful and Mac can help with parts. Mart. |
01-30-2016, 12:42 PM | #3 | |
Re: 1947 Car trans
01-30-2016, 06:27 PM | #4 |
Re: 1947 Car trans
Thanks for the info, I need to get as much info/research as I can to get everything lined up.
01-31-2016, 09:18 AM | #5 |
Re: 1947 Car trans
As mentioned Mac Van Pelt sells good quality parts and will also give you good advice on your build.
John |
01-31-2016, 03:47 PM | #6 |
Re: 1947 Car trans
04-17-2016, 01:50 AM | #7 |
Re: 1947 Car trans
Ok, it's really time to get the parts in order as reverse is out now (just pulling it in and out of the garage to work on other stuff).
Preferences on on clutch, cover and t/o bearing anyone?. Also need to replace pedal bushings. |
04-17-2016, 10:00 AM | #8 |
Re: 1947 Car trans
Being as how you are in South OC C&G in Escondido or The Early Ford Store in San Dimas would be a good source for local parts or Van Pelt's as already mentioned.
Making the simple complicated for over 30 years. |
07-11-2017, 02:22 PM | #9 |
Re: 1947 Car trans
I need to rebuild my 47 trans as well... besides the parts from VanPelt... where can I get the early 41 style engine/trans stability rods to keep from having my trans mount & motor mounts from going bad due to flex/road conditions?
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
07-11-2017, 02:23 PM | #10 |
Re: 1947 Car trans
Van Pelt will have them too. Or put a want ad here on the barn. They are pretty common so you should have them in no time.
07-11-2017, 02:48 PM | #11 |
Re: 1947 Car trans
I would highly recommend fort wayne clutch for all your clutch needs
07-11-2017, 02:51 PM | #12 |
Re: 1947 Car trans
The "Green Book" shows 15 different cluster gears. They vary from 26 to 28 teeth on the main gear, and two types of bearings. C&G sells kits for 39-48 models with three gears. The cluster is 28 teeth. If you plan to overhaul the transmission, you may consider this kit.
07-11-2017, 03:02 PM | #13 | |
Re: 1947 Car trans
07-11-2017, 08:45 PM | #14 |
Re: 1947 Car trans
Thanks for that... I will check with VanPelt... Totally simple set-up
07-12-2017, 04:59 AM | #15 |
Re: 1947 Car trans
Actually I think I may have a set of 41 rods at the transmission shop. I'll be there today and will check...... Mac
07-12-2017, 11:35 AM | #16 |
Re: 1947 Car trans
Thanks,MAC VP.. I will PM you
07-12-2017, 01:18 PM | #17 |
Re: 1947 Car trans
We had two sets of the 11A radius rods (anti-chatter rods). I've PM'd Walt but for those wondering, I am posting here as well. The 11A-6044 rods are only listed for use with the 1941 V8 engines. Walt has a G series six cylinder and those did not have a comparable rod listed by Ford.
07-13-2017, 12:21 AM | #18 |
Re: 1947 Car trans
Do the rods help for a '47, to keep the new trans mount from breaking. BTW, I did rebuild the '40 trans, used the '47 retainer and a bunch of parts from VanPelts...plus his trans book. Works great now and 1st gear is quite for the first time since I bought the car.
