Old 02-18-2022, 07:59 PM   #1
backrodebob
backrodebob's Avatar
Default what yr is 8ba
is there another way to tell what yr an 8ba is? besides the numbers!
backrodebob is offline   Reply With Quote
Old 02-18-2022, 09:41 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: what yr is 8ba
What part(s) are you seeing "8BA" on? In other words, what makes YOU consider it to be an "8BA"? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-18-2022, 09:42 PM   #3
19Fordy
19Fordy's Avatar
As far as I know there is no way to tell the definite year of an 8BA bare block.
However 49-53 Merc blocks were sometimes numbered on the intake manifold surface of the block. Plus, some had hardened valve seats and some did not.
Also, early style had wide belts and later had 3/8 narrow belts. If you have the entire assembled engine, the components may give a clue as to what year it is. You may also have an 8RT truck engine with rotator style valves as a clue. Oil pans may offer a clue.
Peruse the info. below for more details.
https://www.google.com/search?q=how+...hrome&ie=UTF-8
Old 02-18-2022, 09:59 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
"19Fordy" offers about as definitive of an answer as you're gonna find. DD
T5 W/TORQUE TUBE
Old 02-18-2022, 10:10 PM   #5
backrodebob
offy heads and intake, can’t see but a partial number! bought it from a lady whose husband passed, all the paperwork that she gave me only said 8ba 49-53 plus it has 24studs, so I figured it was correct?
Old 02-18-2022, 11:56 PM   #6
cas3
Paper work only said 8ba because thats really about all that can be said about it. None of the casting #'s on the block mean anything except to the foundry that made it. No vin #'s normally, so...its an 8ba. If it was a complete original motor some guesses could be made from the accessory's on it, but as of now, its an 8ba
Old 02-19-2022, 12:48 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
And that is essentially ALL that really matters! DD
T5 W/TORQUE TUBE
Old 02-19-2022, 02:06 AM   #8
cas3
Correct as usual DD
Old 02-19-2022, 10:51 AM   #9
19Fordy
19Fordy's Avatar
Bob:
Read the first two threads listed here that discuss this topic.
https://www.fordbarn.com/forum/searc...rchid=26756988
Old 02-19-2022, 04:46 PM   #10
old school rodder
if the heads are off, take a look at the water passage shapes. Then log onto Van Pelts and look at the pictures of the blocks and their water passages that they list on their web. That could give you more information about what era block you have.
old school rodder is offline   Reply With Quote
