Old 04-26-2021, 03:53 PM   #1
Elevatorman38
Default Top lift cylinder
I’m replacing top lift cylinders in my 46’ Ford super deluxe convertible. What fluid goes in them?
Elevatorman38 is offline   Reply With Quote
Old 04-26-2021, 04:03 PM   #2
Tony, NY
Default Re: Top lift cylinder
If you bought new ones, it should say somewhere in the instructions. My new ones for a 59 Caddy take auto trans fluid. The old ones used brake fluid. Are you replacing the pump? That controls what fluid you actually use. I'm not familiar with the Ford setup.
Tony, NY is offline   Reply With Quote
Old 04-26-2021, 04:32 PM   #3
Elevatorman38
Not replacing the pump, the info that came with the cylinders, said to use hydraulic fluid on cars late fifty til now, I called to ask what they recommended and was told that it depended on what was used previously, that some used brake fluid. The fluid that’s coming out is reddish in color.
Old 04-26-2021, 07:37 PM   #4
paul2748
paul2748's Avatar
I would suggest trans fluid or hydraulic fluid. If your not sure what is is there now, clean out all the old stuff and use either mentioned above.
I use trans fluid in my 48, but I am using a later pump - not sure that makes a difference.
If you get a leak or a line blows, using brake fluid can raise the devil with your paint.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-26-2021, 08:39 PM   #5
Elevatorman38
Thanks for your input!
Old 04-26-2021, 09:22 PM   #6
Lawson Cox
Lawson Cox's Avatar
Red sounds lite ATF (fluid, to be redundant.)
