Old 08-13-2017, 08:52 PM   #1
FlatheadTed
FlatheadTed's Avatar
Default Diode
This might be a Model question but I have used the Diode available from Snyder's on the Model a Generators, but have found they heat up .If you fit the covers on there's no cooling and can burn out , any one experience this ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-13-2017, 09:30 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Diode
Are you talking about using them inside of a cut-out on top of the generator?
John
Old 08-13-2017, 09:44 PM   #3
FlatheadTed
Default Re: Diode
Yes Jim ! Thanks ,Ted
Old 08-13-2017, 11:03 PM   #4
JM 35 Sedan
Default Re: Diode
I guess they could run hot if there is a heavy current demand on the electrical system, and third brush is set to max. I had purchased some diode kits to use in the cutouts on my 35's, but once I found out about the Fun Projects electronic regulators, I use those on all my cars.
Maybe you could mount your diodes on larger heat sinks that would still fit inside the cutout can, but do a better job of soaking the heat from the diode.
John
Old 08-13-2017, 11:48 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Diode
I just used a diode out of a junk delco alternator, gutted the windings out, drilled ahole in the reley frame, pressed the diode in ---never measured the temperature, but it had been working at 18 amp for awhile, now 14 amp----untouched over 30years, so if it is getting hot it is within design allowances
Old 08-14-2017, 12:00 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Diode
Take a block of aluminum. Drill the hole for the diode. Mount the heat sink to where the instructions say to mount the diode.
Old 08-14-2017, 12:28 AM   #7
flatheadmurre
flatheadmurre's Avatar
Default Re: Diode
Tumb rule for heatsinking semiconductors...if you can touch it and count to 10 it´s ok.
And that is fairly hot...
Old 08-14-2017, 12:47 AM   #8
Paul Bennett
Default Re: Diode
Silicon power diodes have a voltage drop of 0.7v. So with 20 amps current the power dissipated by the junction would be approx 14w. Removing the heat into a heat sink depends upon how the diode is made elsewise the temperature will soon destroy the diode junction.
For a power application best NOT use an axial diode but one with metal tab which has a hole to mount to a heat sink, or which has a stud to screw into a heat sink.
Paul Bennett is offline   Reply With Quote
Old 08-14-2017, 12:57 AM   #9
FlatheadTed
Default Re: Diode
Thanks for the replies' .Here's a couple of shots .I drilled a air vent in one ,if the battery is fully charged and you are running at say 8 to 15 Amps maybe that's were the excessive heat comes in Ted
Old 08-14-2017, 03:33 AM   #10
Karl
Karl's Avatar
Default Re: Diode
Ted I ran one on my first Model A-Did 12 ,000 miles and no overheating I sold it to a guy in Napier who I am still in touch with and he uses it as his daily driver and has done for the last 5 years with no problems. From memory was mounted pretty much as yours is -Karl
Karl is offline   Reply With Quote
Old 08-14-2017, 07:03 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Diode
That is not original cutout, the metal frame the diode is mounted on has less mass and is mounted on a thicker insulating block. -- try modifying an original cutout
Old 08-14-2017, 02:34 PM   #12
FlatheadTed
Default Re: Diode
Thanks for all the replies ,I like the idea because its a $2 item ,I have only burnt one out ,I think I will run two one as a back up ,Ted
