Old 03-17-2018, 10:00 AM   #1
BillCNC
BillCNC's Avatar
Question Tail Light Part Question
Hey All,
I was wondering if anyone uses the Tail Light Snap Ring part # 19110
If so, ... does it really help?
I ask because I dropped and broke one of my lenses yesterday trying to get it all lined while installing the lenses. I tried to get a pair yesterday at the Early Ford Store when I picked up a new lens, but they were unaware of the part and didn't carry it.
If you have some, could you please measure the diameter of the wire so I can make a pair.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-17-2018, 10:10 AM   #2
700rpm
700rpm's Avatar
Default Re: Tail Light Part Question
They help, and they seem to be almost spring steel. Not sure you could make effective rings from plain wire, but maybe you have something else in mind. The wire diameter is about 3/16. I suggest just ordering a couple. They fit the inside diameter of the lens bezel.
Ray Horton, Portland, OR
Old 03-17-2018, 10:34 AM   #3
BillCNC
BillCNC's Avatar
Thanks 700rpm,
I have tons of Music Wire (spring steel) here in a whole slew of sizing. I'll look at 3/16" (.187) and some 1/8" (.125) and construct a pair.
When installed, do the end's touch or is there just a small amount of spring tension holding them in?
Regards
Bill
Old 03-17-2018, 10:45 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by BillCNC View Post
Thanks 700rpm,
Regards
Bill
Bill,
Are you a "PIANO" man? It's AMAZING what PROFESSIONS/HOBBIES some Folks have! I heard of a Man that builds 3/4 Scale, REAL Stagecoaches! Some were used in "TALES OF WELLS FARGO" SERIES!
The mark of a REAL CRAFTSMAN is to be able to cover up your mistakes, UNDETECTED!!---LOL (Break out the BONDO!) We make jokes about Bondo, but what would we do without it? (Or Wood Putty)
Bill Dabbler of Sorts
"THE ASSISTANT GURU OF STUFF"
Old 03-17-2018, 02:43 PM   #5
katy
katy's Avatar
Ifn it's not there, what's holding the lens in?
That ring should have an upset near one end to facilitate taking it out.
Old 03-17-2018, 03:37 PM   #6
700rpm
700rpm's Avatar
Thanks 700rpm,
Regards
Bill
Mine have a little gap, about 1/8’’. I think this is to aid R & R.
