08-23-2020, 07:35 PM | #21 |
Re: Wheels, would like opinions.
Wow love it. Hope you are going to keep it all original!
08-23-2020, 10:15 PM | #22 |
Good decision. Save your 15 inch rims.
08-23-2020, 10:31 PM | #23 |
To me, red and green is Christmas colors. Never liked it on any car.
Not sure why you would care what everyone else thinks anyway. Do whatever look and style you really like. And change it when you want to. |
08-23-2020, 10:49 PM | #24 | |
Biggest reason is sometimes someone will suggests something I like better than my ideas!! Sent from my iPhone using Tapatalk |
08-24-2020, 03:21 PM | #25 |
For what its worth, I run 15" wheels with bias plys and tubes. I have not had any problems with the ride or handling.
I think painted wheels is the way to go. Two rattle cans and an afternoon, and you can have a completely different look. My coupe has had black wheels, red wheels, stock caps and rings, chrome bullets, and currently burnt orange wheels in SATIN, with flipper caps. Bottom line, have fun with it, and don't be afraid to change it up whenever the mood strikes. |
08-24-2020, 03:56 PM | #26 | |
This is the 4.5? Sent from my iPhone using Tapatalk |
08-24-2020, 03:56 PM | #27 |
And this is the 4?
08-24-2020, 05:06 PM | #28 |
The one with square shoulders is a 4". The other one might be a 4" or a 4.5". Measuring between the beads is the only sure fire way to tell.
Oh and for what it's worth, I think it looks ok on the existing wheels. It would look good on the 16s. I agree with the comment above, the red does not suit a green car. I think maybe it might just be worth painting the 15s cream or something like that. That would tide you over until the 16s are ready. Definitely not smoothies, but we have already established that as a given. Mart. |
08-24-2020, 07:27 PM | #29 |
DMMuir .....You got it backwards, kind'a like Mart indicated above. Here's the deal. All '40 and '41 Ford wheels were 4"-wide between the beads. Virtually all of the 4"-wide wheels had the two PARALLEL, vertical surfaces like your first picture above.....ALTHOUGH a few folks contend that SOME late '41 4"-wheels have the "ONE-SIDE-SLANTED" drop-center. I have never personally seen one of these critters, but would love to see a "one-side-slanted" wheel that actually measures only 4" between beads. GENERALLY, you can count on the "one-vertical-surface-slanted" wheels as being '42-'48, and being 4-1/2" between beads. And be careful, as there are a bunch of 'similar-appearing' 15" wheels that came on '53-'56 pick-ups that had the "one-side-slanted" configuration which are 5", AND 5-1/2" wide....BUT they are ONLY15" wheels!
I see that your 4" wheel above was green like the car. If you have four wheels that are green like that, had you considered ONLY blasting the inner part of the wheels (including the INNER beads) where the tire is mounted, maybe leaving the original paint and 'character' on the visible part of the wheels.....possibly more in line with matching the 'used' (yet original) look already on the car? Just a thought, although you'd be better off using 4-1/2" wheels if you have access to four of them! If you've maybe considered the 'big 'n little' tire look, you could always run two 4-1/2" wheels in rear, and two 4"-ers in the front. Many, including myself, have done that. DD |
08-24-2020, 07:57 PM | #30 |
I like the red wheels and think the wheel/tire combo looks good on your car.
08-25-2020, 11:25 AM | #31 |
i have a "slanted" 16x4" wheel that i bought from joe mac at ford obsolete [many years ago]. he said it was a post -war wheel sold over the parts counter.
08-27-2020, 05:33 PM | #32 |
I'm confused about the wheel differences. I compared in the garage today and I only have 1 with the slant. But they measure exactly the same. The caliper pics below don't show measurement, but it was not adjusted between wheels....
@V8Coopman, I may have found your uber rare 4" slant wheel makes sense I only have 1 out of my 7 wheels Last edited by DMMuir; 08-27-2020 at 05:43 PM. |
08-27-2020, 05:43 PM | #33 |
I wish I could blast surfaces only, but the wheels are too rusted. several don't really have any paint left. I will probably have a local paint supply color match the car so they look right.
08-27-2020, 09:30 PM | #34 |
The wheels you show that measure 5 & 3/16" (or so) outside measurement, will
measure 4" inside to inside the beads. The '40 and '41 wheels, as in post # 26, have the flat surface around each lug hole. Most all steel wheels, I've seen, made in '42 and newer will have the metal around each lug hole volcano'd out which ads strength to the lug hole. Circle track racing these old Fords back in the late 50's and early 60's, we would not use the '40-'41 wheels as they would get cracks in the metal around the flat lug holes. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
08-28-2020, 12:46 AM | #35 |
I had a green 40 DeLuxe like that in53/54.bought it off a used car lot for $70.
I would keep the 15 inch wheels on a driver. Much, much cheaper and easier to buy tires for. I bought 15 inch wheels for my 51 F1 and my 48 Nash Ambassador. Went to Walmart n bought tires for 1/3 the price of 16 tires. And no tubes required. And nobody points at me and laughs because I have the wrong size tires as I drive down the street. |
08-28-2020, 08:06 AM | #36 |
Wow, your '40 looks a lot like mine. I'm running black stock 16 inch wheels with standard caps and wide whites.
08-28-2020, 10:49 AM | #37 |
Back in the sixties we called the lug holes as belly buttons. The earlier wheels through '41 were innies, while the later wheels were outies. The formerly sought after 1941 only Lincoln wheel (innies) were 16X5 where the later Lincoln wheels were 15X6 and used different caps like the Merc. Ford pickups in the sixties could be had with a 16X5 but the lug holes were outies and may have had a different offset. Rare ones? Whatever! Have fun with the color. Good Luck: Fred A
08-28-2020, 12:25 PM | #38 | |
08-28-2020, 04:34 PM | #39 | |
. . . The description of wheels, known as "innies" or "outies" is referring to the "hubcap mounting nubs", Not the lug holes. The hubcap mounting nubs faced "inward" on most FoMoCo cars and pickups thru '65 or real early '66...Then the hubcap mounting nubs changed to larger "outward" facing hubcap mounting nubs. .
08-28-2020, 09:16 PM | #40 |
So,
I would like to find 16" wheels, preferably 6 inch or so wide. That way I can keep the original look and actually put a little bit of tire under there. Anyone know a source? I would like the trim rings and centers I have to still work. |
