02-15-2015, 10:25 AM | #1 |
1932? small parts id help
OK guy, more NOS small parts. Supposed to be all 1932. starting from the left.
1. b-37708-a ?? 2. ?? Notice 2 piece design and oval mount holes (to adjust ?) 3. b-14605 ?? has a slanted hole 4. ?? cone shaped 5. ?? All grommets are split. |
02-15-2015, 12:07 PM | #2 |
Re: 1932? small parts id help
Two out of five are '32 parts. The large capped nut on the far left is for one side of a deluxe '32 roadster or phaeton top iron to body attachment (also '30-'31 versions of those body types for either side if the threads are right hand). In the case of the '32s that side will depend on whether the threads are right or left hand. They appear to be right hand threads in the photo, but I can't swear to that.
The round grommet in the center is for early four-cylinder '32s that had hand controlled starter motor switches. That grommet was placed in the firewall to protect the Bowden cable that was mounted on the left side of the steering column support and passed through the firewall en route to the starter motor switch mounted on top of the starter motor. Late '32 four bangers had foot operated starter motor switches and that grommet was no longer used. The remaining three item all have post-'32 applications. |
02-16-2015, 02:35 PM | #3 |
The part at 3" might be a hood hinge mount for '33-4 truck.
02-17-2015, 07:31 PM | #4 |
I agree with Bruce about the part at 3 inches being for a pickup. I think it wouold work on 35/6 as well.
02-18-2015, 10:13 AM | #5 |
