06-27-2018, 06:59 PM | #1 |
lincoln transmission ?
i recived a transmission today witch i think is a lincoln .it is a side shift. it has the big bell. it has a long clutch release arm. it has a hole in the side cover for i think a clutch pivot . the shift levers are long . it has the needle bearing u joint. the number on the back is 1a-7006-22 i thought all lincoln side shift trans have over drive. this is not an over drive trans what do i have here sorry i can,t post phots. called van pelt never returned my call may be he is on the road
06-27-2018, 08:15 PM | #2 |
Re: lincoln transmission ?
Most Lincolns had OD, but a few did not. Those with out OD had a shorter transmission and a longer drive shaft.Check the VIN which is above the inspection hole in the top forward of the transmission. The Vin would start 8H xxxxxx for a 1948, 7h xxxxxx for a 1947 etc.
06-27-2018, 08:30 PM | #3 |
They also had a different style tail mount then a ford speed. Everything you mentioned so far is the Lincoln 3 speed. Take the side cover off and see if the input shaft has a half moon cut in the fine teeth for the syncronized (third or high gear were it engages)
06-28-2018, 10:07 AM | #4 |
1A sounds like 1951 Ford but that doesn't totally fit the description. Photos are a way lot better for good ID.
06-28-2018, 12:06 PM | #5 |
