04-27-2022, 03:12 PM | #1 |
37 rear toque ?
Hi, I need the toque # for the end bell bolts and the toque tube bolts. Thanks Jim T.
04-27-2022, 04:41 PM | #2 | |
Re: 37 rear toque ?
Cinch 'em up good 'n snug and be done with it! Coop . |
04-27-2022, 04:54 PM | #3 |
Re: 37 rear toque ?
What Coop said, and I’m not sure you could even get a proper torque reading on the bell bolts anyway, being’s those bolts are interference fit to prevent leaks.
Alan |
04-27-2022, 05:59 PM | #4 |
Re: 37 rear toque ?
On my '39 I made the mistake of chasing the threads before I knew they were interference fit so there may have been less meat there when I took these numbers: I had an unsalvageable banjo so I decided to test where they failed. None failed at 30 ftlbs, a few at 35 failed and the rest went at 40.
04-27-2022, 08:07 PM | #5 |
Re: 37 rear toque ?
As far as torque specs for any given bolt, look up general torque specs and use the spec for the size and thread count of what you have.
04-28-2022, 05:38 AM | #6 |
Re: 37 rear toque ?
