03-12-2021, 03:39 PM | #1 |
Pinto 2.O transmission options
Without engaging in the pros/cons of a Pinto engine in an A, would a Mitchell overdrive be a preferred option than a Mitchell Synchro transmission to accommodate the engine's higher rev's ?
03-12-2021, 04:11 PM | #2 |
Re: Pinto 2.O transmission options
IMO, NO! An under drive might be a better idea if you're using a Model A rear end.
03-12-2021, 07:44 PM | #3 |
03-12-2021, 09:59 PM | #4 |
I'm not the right person to talk to about this one - we didn't see any Pintos over here.
03-12-2021, 10:37 PM | #5 |
Model A original transmission combined with a
Mitchell overdrive that they turn into a underdrive. Works very well! Gil. NoCal |
03-13-2021, 12:02 AM | #6 |
Charlie Stephens |
03-13-2021, 08:32 AM | #7 |
We have a local company here that started out making bell housings for dirt track racers. They could make a bell housing for you, so that you could bolt up any engine to any transmission. Dirt track racers are nuts! The name of the company is "Quick Time". They might be able to help you figure out what you are trying to do. Located in in Southern Iowa.
