03-18-2019, 08:04 PM | #1 |
PCV on 8BA
I connected the PCV valve and am doing some testing. Prior to adding the valve the vacuum was running around 18 inches. After putting on the valve the vacuum drops to around 5 inches. The only obvious effect is the RPMs go up slightly. There does not seem to be any other change in the engine operation. My question is what is the real effect in the drop of vacuum? Does it adversely effect the engine in any way. I admit I really do not know much about the vacuum system on an 8BA. Thank you in advance for any comments.
FORD RANGER |
03-18-2019, 08:09 PM | #2 |
Re: PCV on 8BA
Your windshield wipers won't like it. 8^) Jack E/NJ
03-18-2019, 08:14 PM | #3 |
Re: PCV on 8BA
It is going to mess with the air/fuel ratio. Be sure it is not running lean!
03-18-2019, 08:45 PM | #4 |
Re: PCV on 8BA
I read about others installing a PCV system and swear by it, taking the fumes away. Is there a way to connect the valve without losing vacuum? Does that mean the road draft tube is the best way on those old engines ?
FORD RANGER |
03-18-2019, 09:50 PM | #5 |
Re: PCV on 8BA
Which PCV valve are you using? The best I found is Fram p/n FV306, used on many Toyotas and Lexus's. Much better built than the typical small-block Ford PCV.
'52 F-1, EAB flathead |
03-19-2019, 05:28 AM | #6 |
Re: PCV on 8BA
03-19-2019, 05:36 AM | #7 |
Re: PCV on 8BA
03-19-2019, 06:55 AM | #8 |
Re: PCV on 8BA
If you are adding air to the intake manifold after the carburetor it will change the a/f ratio (more air added to the mixture) and possibly lean it out. Similar to a vacuum leak. If the carb has power valves, a lower manifold vacuum can be an issue as well.
03-19-2019, 08:24 AM | #9 | |
Re: PCV on 8BA
But some time in the future, just for HaHa's I plan to do a test by momentarily dis-connecting and connecting the vacuum source to see if there is any change in the A/F reading.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 03-19-2019 at 08:31 AM. |
03-19-2019, 08:42 AM | #10 |
Re: PCV on 8BA
I'm running a PCV on my 8ba. Valve is for a 231 Buick. Engine is stock with a 94 redone by CharlieNY and a Bubba Chevy mechanical advance distributor. I didn't have to make any adjustments when I installed the PCV set up. Engine runs smooth and strong. No issues since hooking it up.
Making the simple complicated for over 30 years. |
03-19-2019, 10:44 AM | #11 | |
Re: PCV on 8BA
03-19-2019, 01:24 PM | #12 |
Re: PCV on 8BA
My 8BA has a standard Holly 94, I get the vacuum from the windshield wiper port right above the intake manifold. I bought the PCV system from the one recommended on Ford Barn, the vender is Western Chassis. Am I doing something I should not?
FORD RANGER |
03-19-2019, 02:18 PM | #13 |
Re: PCV on 8BA
>>>taking the fumes away>>>
Do it the easy way. Get a Chrysler-style hose-barb oil-filler cap for the fuel-pump stand. Run the 5/8 or 3/4 hose to the air cleaner. Jack E/NJ |
03-19-2019, 02:23 PM | #14 |
Re: PCV on 8BA
That works for a low level of crankshaft ventilation, but it is not PCV. I'm not a big PCV fan on a flathead myself, so it could be an option, but just to be clear it is not PCV.
03-19-2019, 03:12 PM | #15 |
Re: PCV on 8BA
OK. How about calling it lowercase pcv for passive venting and uppercase PCV Positive Venting? That should clear things up. 8^) Jack E/NJ
03-19-2019, 03:16 PM | #16 |
Re: PCV on 8BA
03-19-2019, 04:47 PM | #17 |
Re: PCV on 8BA
Jack E/NJ, do you have a part # for the Chrysler hose-barb filler cap? That sounds like what I want to do. I do not like messing with the vacuum.
FORD RANGER |
03-19-2019, 06:06 PM | #18 |
Re: PCV on 8BA
Stant 10070, Mr Gasket 2063, etc. You might have to adjust the center 'whatchacallit' a bit to fit snuggly in your pump stand pipe. Jack E/NJ
03-19-2019, 06:22 PM | #19 |
Re: PCV on 8BA
When you say pump stand pipe do you mean the oil filler tube?
FORD RANGER |
03-19-2019, 06:48 PM | #20 | |
Re: PCV on 8BA
You're doing something wrong, because there should only be a very small (if any) vacuum loss with a correctly plumbed and valved PCV system. A picture or two and valve info would be helpful. Keep in mind the oil fill on an 8BA is also the crankcase ventilation air intake, which should see max available atmospheric pressure, not possibly reduced pressure resulting from using the Chrysler style cap plumbed to the air cleaner. |
