11-18-2023, 06:18 AM | #1 |
More questions on my 39 Deluxe
I'm working on getting my 1939 Ford Deluxe to where I can drive it regularly. I'm dealing with a coil/condenser issue but have that in the works (Thanks in advance Skip!). While I am waiting on the coil issue to be resolved I want to work on some small items needing attention. I need a key for the trunk/glovebox made as it came with no key. I would like to remove the glovebox lock to have a key made as I can't drive the car to a locksmith. Hopefully the truck will be keyed the same. Is there a small metal clip that retains the cylinder? I have an original factory owner's manual but no service manual. The weatherstripping has been replaced on the glass and trunk seal but the trunk won't close completely to allow the latch to catch. Should I move the strike plate? Thanks!
11-18-2023, 08:12 AM | #2 |
Re: More questions on my 39 Deluxe
Hello…had the same key issue….contact 32phil….he took me from no key no code to working locks on both glove box and trunk….without his advice I would have just assumed the trunk lock was different from the glove box….good guy
11-18-2023, 08:18 AM | #3 |
