03-08-2020, 02:37 AM | #1 |
Bob Drake rear anti-sway kit 1935-40
The small print on this says 35/36 needs to use 37-48 rear end. Can anyone tell me where the difference is that makes it incompatible with stock 35?
03-08-2020, 03:14 AM | #2 |
Re: Bob Drake rear anti-sway kit 1935-40
The location of the radius rod brackets on the axle tubes.Sent you an email.
03-08-2020, 11:27 AM | #3 |
And a '37-'40 rear end with torque tube, drive shaft and spring essentially bolts-in dimensionally. That leaves brakes and wheel bolt pattern as about the only details to be addressed. DD
03-08-2020, 12:29 PM | #4 |
Little hard to see, but this might show the differences.
03-08-2020, 04:28 PM | #5 |
