03-05-2019, 12:50 PM | #1 |
AF700441 is this a big bore engine?
Hi,
In 2 days I want to buy an A. Now I have seen the engine number above. I have read, that this numbers were transfered to Manchester in Dez 1928 and they produced small bore engines. Is this true? The number is AF*700441* Thank for some fast answers. Willi Last edited by wkuehnis; 03-05-2019 at 01:11 PM. |
03-05-2019, 12:56 PM | #2 |
Re: AF700441 is this a big bore engine?
How can I easy check if it's a big bore?
Willi |
03-05-2019, 01:08 PM | #3 |
03-05-2019, 01:10 PM | #4 |
From fordgarage.com;
An 'F' in the prefix of a British-built engine indicates the small bore engine, not whether it was for a RHD or LHD chassis. Large bore British-built engines did not carry the 'F' in the engine number prefix, nor did RHD English-produced chassis. The 'AF' in the engine number and in the vehicle Model name indicated only that the British-produced vehicle had a small bore 14.9 HP (R.A.C.) engine. http://www.fordgarage.com/pages/ABenginenumbers.htm There were pictures I saw recently about the differences between the small and big bore engines but I haven't been able to find the post here yet. Definitely sounds like you have the small bore engine though. |
03-05-2019, 01:11 PM | #5 |
03-05-2019, 01:17 PM | #6 |
03-05-2019, 02:22 PM | #7 |
The AF 3" bore engine block was cast at Fords Cork Ireland tractor plant where they had a foundry which Manchester did not . Final machining and assembly was done at the Manchester plant . The small bore engine was available in France and Japan and most likely in other countries who had a "horsepower tax" Vehicles fitted with the AF engine had a chassis number starting AF same as an A would with the engine number . The "F" indicates "Foreign" and RHD parts also carry an "AF" prefix . Late English built AA trucks have some parts that were only fitted in England and nowhere else these have AAE prefixes indicating England . Confusion has arisen as some English built AA trucks are described in period Ford adverts etc etc as AAF this did not mean they were fitted with the small bore engine it just meant they were not identical to a USA built AA truck as they were RHD . The small bore engine produced 28 BHP @ 2600 RPM . They were hard pressed to pull a Briggs Fordor with 5 passengers let alone pull an AA truck .
John in windy spring weather rain and more gales on the way Suffolk Couney England . PS my 28 phaeton has the AF engine wich is way smoother than the A engine . It is fine in flat country but you can sure tell the difference on hills . Gas mileage is just the same . Last edited by john charlton; 03-05-2019 at 02:28 PM. |
03-05-2019, 05:44 PM | #8 |
I have seen an AF stamped large bore engine, that originated from Argentina.
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
03-05-2019, 10:51 PM | #9 | |
Also, Ford Canada also could provide the small bore engine but I do not yet know whether they cast their own or used the Cork engines for S.B. Canada export records show SB cars sent to Singapore & the odd East African country. It was only a small amount of vehicles, so I would guess they used the Cork engine. Cheers Tom in NZ. |
03-06-2019, 12:15 AM | #10 |
Thanks for your help !
I will not buy it, because the small bore would not be funny in our mountains. Willi |
03-06-2019, 08:21 AM | #11 |
Wise Decision! The "Mountains" of Pennsylvania are just bumps in the road when compared to the Alps. My A coupe with a bored out engine, High Compression head, B carburetor, bored out manifold and 3.54 rear makes it over them pretty good, but I wouldn't want any less Horse power.
Terry |
03-06-2019, 03:32 AM | #12 |
Is the AF number stamped into the engine Block or just listed on the Paperwork?
A lot of times these engines have been changed over the years. sometimes the paperwork is not up to date The best way to find out what you have there is to look at the cylinder casting outline on the water outlet side , If there is a flat spot between number 2 and 3 cylinder outline of 2 inches or so that is the Small Bore engine. In that spot on the Big Bore engine you can just barely get your fingers in the space The Small Bore engine was available in many European Countries including France and Holland. They also made a Model B version with a BF number it had a hotter cam and a lighter flywheel John Cochran |
03-06-2019, 10:45 AM | #13 |
John Charlton Glad to see you are still posting Havent seen one from you for a while Ray
03-06-2019, 03:10 PM | #14 |
Thank you Ray !!! .Got side tracked a bit on a 1942 Ford GPW Jeep hope to get ready for Normandy June 6th which is my 80th birthday as well .It is not a Model A but it is a Ford!!!
Regards John. |
