03-12-2018, 07:36 PM | #1 |
running board rubber glue?
I have the new running board pyramid rubber mid-1930 Cabriolet that comes with a white paper covering adhesive backing that is peeled off to stick them on.
Is this good enough, or should I use some additional weatherstrip adhesive to hold it down before I start to install the zinc strips that hold down the edges?
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
03-12-2018, 11:14 PM | #2 |
Re: running board rubber glue?
I have only used contact cement so I can't help you with experience but if I were in your shoes I would add the adhesive.
03-13-2018, 01:07 AM | #3 |
I have new mats that I will be installing soon, no self adhesive on these, I'll be using some of the super 3M stuff.
03-13-2018, 07:31 AM | #4 |
3m1300l
03-13-2018, 07:49 AM | #5 |
Barge rubber cement...............
03-13-2018, 09:07 AM | #6 |
Rusty Nelson |
03-13-2018, 09:19 AM | #7 |
3M spray is much easier to get on evenly and avoid bubbles.
03-13-2018, 10:46 AM | #8 |
The last Swap Meet that I attended I spoke with a fellow that sold running board rubber and installed them. I asked what adhesive he used and he showed me this: GM 550 Polyurethane Adhesive Sealant Fast Cure.
03-13-2018, 01:30 PM | #9 |
Afordman31,
Is the GM adhesive a spray or is it applied another way (brush maybe)? I am about ready to put the matting on my 29 phaeton runningboards and don't want to have trouble(bubbles) like I did with the coupe using contact cement. Rusty Nelson |
03-13-2018, 01:48 PM | #10 | |
3M makes SEVERAL differing spray adhesives. I've used different types of 3M spray, depending on what I need to happen with job. For instance, one type spray tacks/dries more slowly and you get a small window for shifting part. Whereas, another spray keeps the part(s) in place immediately. Choose wisely. All are great at what they do ! |
03-13-2018, 02:39 PM | #11 |
What was it like in "bygone" days, WITHOUT the modern GLUES/ADHESIVES, that we enjoy NOW? They'd glue something, let it sit for DAYS & it'd jist fall apart +=*$^%#$^ (PROFANITY that I can't display HERE!)
Bill Cleantalkersometimes
03-13-2018, 08:17 PM | #12 |
In the old days they had good glue from horses.
03-14-2018, 08:02 AM | #13 |
Was in a tube Rusty, not spray. He said that there was working time and that he had weighted the running board rubber after getting it in position!
03-14-2018, 08:38 AM | #14 |
From their HOOVES, I "think"???
How about JACKASSES/DONKEYS/BURROS/MULES/ETC ??? Bill Pondering again
