02-20-2015, 05:36 PM | #1 |
Need ideas to get the rest of this temp sending unit out of the head
I was going to put in an electrical sending unit in today, the remnants of the capillary one had been snipped before I got the engine...so I unscrewed the remnant...and am left with the pic shown below...my thoughts are to use a small punch and tap it down some to break free and rust that is holding it in place..then grab it with a pair of dykes and try to pull it out.
I could move the wiring/etc away, and heat the area up with a welding tip... But...here's my concerns if I tap it down to free it up...if I tap to far..will it fall into the block? Rather not pull the head, as I don't have another gasket available, but it may come to that I guess? Thanks in advance. |
02-20-2015, 05:40 PM | #2 |
Re: Need ideas to get the rest of this temp sending unit out of the head
I've got a KR Wilson Pusher tool that curves into the hose opening and pushes up on the bulb as it is tightened...but I'm not willing to entrust an irreplaceabe tool to the mail. Maybe someone out thataway has one.
Perhaps you can run a tap into the remainder and pull from the tap or with a piece of threaded rod as a slide hammer... |
02-20-2015, 05:47 PM | #3 |
Tapping it down is not going to work as there is a small lip inside the head at the bottom of the threads. The bulb seated against it. The later heads with the electric probe had threads all the way down the bore.
02-20-2015, 05:49 PM | #4 |
That might be an option Bruce...looks like I'd have to drill it off center..gonna go grab my mirror and see what it looks like in there..and suck up the PB blaster as well
But, if you'd be able to take a pic of your tool and post it here, it woud be much appreciated, and give me an idea or two, maybe. Thanks |
02-20-2015, 05:53 PM | #5 | |
Looks like Bruce's Idea of drilling and slide hammer might be the way to go here...worst case I have to pull the head...but gota try something before hand. Thanks |
02-20-2015, 06:20 PM | #6 |
02-20-2015, 06:27 PM | #7 |
Mike, If you remove the top hose, you'll see the 'bulb' protruding into the water jacket. As previously mentioned, this is seated by screwing down the thread you've already removed. So...the bulb is only 'sealed' in place from being there so long, as you've removed the threaded bit. You should be able to stick a punch or similar down the outlet [from where you've removed the hose] and tap the bulb, and/or lever on it with a screwdriver, etc,- work it sideways a bit to break the seal and it should come up and out.
02-20-2015, 06:29 PM | #8 |
Awesome Brian!
Now I see what Bruce meant! Heading back out while I still have daylight, thanks! |
02-20-2015, 06:47 PM | #9 |
You can tap it IN to the head and pull it out of the water (hose) outlet. been there, done that.
02-20-2015, 07:19 PM | #10 |
Got things apart and can see the bulb, so will try some persuasion on it.. Issue I have to drill while in place, I don't have a right angle drill anymore...kinda mocked up my smallest 3/8th drill and do not hink I can get a very straight shot at it due to the firewall, I may whack a drill bit off and look at things again later, but going to try the persuasion route first.
Thanks |
02-20-2015, 07:42 PM | #11 |
I would drill a hole for a #10 self tapping screw at the top end and pull it with a slide hammer.Phil
02-20-2015, 08:42 PM | #12 |
Well, no joy yet I'll try to drill it and tap it and pull it out...but pretty sure I'll be drilling on an angle and pulling it from the same.
One way or another, tomorrow I'l have it done...well..sans a head gasket if it comes to that |
02-20-2015, 08:56 PM | #13 |
May come out easier than you think,just held in by rust and crud! Phil
02-20-2015, 10:09 PM | #14 |
Yes Phil, tried heat and cool...but not budging from behind hopefully I be able to pull it tomorrow!
Thanks. |
02-20-2015, 10:30 PM | #15 |
KR Wilson made a tool for that.
02-20-2015, 11:39 PM | #16 |
Must be the tool Bruce was speaking of?
Thanks for the pics! |
02-20-2015, 11:44 PM | #17 |
02-21-2015, 06:46 AM | #18 |
Try some Kroil and wait a bit and then try tapping it any way you can to break the seal. Maybe some heat with a small pencil tip torch and repear the Kroil trearment. Take some time to let it work. jms kx
02-21-2015, 06:54 AM | #19 |
What about heating and using wax to wick down in as many here have used this process to remove frozen / rusted bolts & studs >>>
02-21-2015, 07:13 AM | #20 |
The threads are 5/8 UNF in a Pilot head.
If you can see the end of the bulb inside, can you just wobble it a bit to get it moving, then push from below while pulling from above. If all else fails, you could just run a drill through it and remove the remnants. The hole in the head does have a seat, Someone may be able to give the diameter. It's between 3/8 and 7/16 from memory. Mart |
