06-07-2020, 04:34 PM | #1 |
Tie Rod End Installation
Bought NEW Pitman Arm because Ball end was worn and have shaking in front end. Also bought new bolt for the Pitman Arm. With approx. 225 in. of torque on bolt nut Pitman Arm is moving fore and aft a SSSSSLLLLight bit. Sector Shaft looks fine although don't know what a good shaft measures to?
Have tried to assemble any way BUT CANNOT get back plug of drag link threaded into drag link. WHAT is the SECRET in installing this plug? Does anyone have any thought on either PROBLEM? |
06-07-2020, 05:02 PM | #2 | |
Re: Tie Rod End Installation
As for the drag link plug, mine was a real bear to get started. Maybe get some help, someone with BIG arms... maybe your MIL?
The Master Cylinder Enjoying life at the beach in SoCal... |
06-07-2020, 06:07 PM | #3 |
The Master Cylinder We adjusted the end play and as far as we can see it is NOT moving.
06-08-2020, 06:23 AM | #4 |
[QUOTE=Cape Codder;1896631]Bought NEW Pitman Arm because Ball end was worn and have shaking in front end. Also bought new bolt for the Pitman Arm. With approx. 225 in. of torque on bolt nut Pitman Arm is moving fore and aft a SSSSSLLLLight bit. Sector Shaft looks fine although don't know what a good shaft measures to?
I have found that the steering box mount bolts to frame holes slightly elongated to trick you into thinking it is the pitman arm to shaft movement. John |
06-08-2020, 06:27 AM | #5 |
Has to be TIGHT, NOT in. lbs........................
Paul in CT |
06-08-2020, 10:18 AM | #6 |
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 06-08-2020 at 10:37 AM. Reason: Added punctuation. |
