Old 02-05-2019, 06:01 PM   #1
Rustyscrap
Angry SLOW starter
The starter in my '31 PU gave up the ghost after 40+ years of faithful service (just totally dead). I attempted an overhaul: cleaned up commutator, new bushings and brushes. It passes all the field continuity tests and the armature spins free, but when I jumper test it on the garage floor the armature just barely turns. Anyone have any advice on what to try next?
Rustyscrap is offline   Reply With Quote
Old 02-05-2019, 06:32 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: SLOW starter
Just my 2 cents worth here:
1) Maybe not getting good current flow through the brushes
2) bent shaft
3) bad ground
I am NO electrical guru and welcome to the Barn!
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-05-2019, 08:50 PM   #3
Synchro909
Synchro909's Avatar
What is your power supply when doing this? Is it capable of maintaining 6 volts when the starter is connected?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-06-2019, 09:58 AM   #4
Gary WA
Gary WA's Avatar
Ground-clean shinny bright and tight!! Out of car??? Getting good voltage ditto#3
www.whidbeymodelaclub.com
Old 02-06-2019, 10:14 AM   #5
katy
katy's Avatar
I would suspect that the brushes and/or the commutator are contaminated w/oil.
Are the brushes still long enough to get good spring pressure against the commutator?
Clean the commutator off w/a good degreaser and try a new set of brushes.
Old 02-06-2019, 12:58 PM   #6
Badpuppy
If the starter switch is mounted during test, that may be the cause.
https://www.fordbarn.com/forum/showp...29&postcount=4
Badpuppy is offline   Reply With Quote
Old 02-06-2019, 04:07 PM   #7
Werner
Werner's Avatar
Hello,
I do not know if I understand the problem correctly.
When starting the cold engine with thick 25W-50 oil, I measure a current flow of about 150 amperes, the voltage drops to <5 volts. Both are normal.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-07-2019, 10:30 AM   #8
katy
katy's Avatar
I believe his problem is the starter itself, not the cold weather.
Old 02-07-2019, 10:56 AM   #9
Smooth_One
Smooth_One's Avatar
Ground issue? Mine was spinning very slow when testing and i added a ground from the frame to the trans bell housing and much better. But if your testing on the floor then maybe you have a starter issue. Volt meters are a great way to narrow down the problem.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-07-2019, 11:19 AM   #10
Patrick L.
Patrick L.'s Avatar
By 'garage floor' I'm assuming you mean the starter is not in the car. Did you test the commutator ? Its an easy test with a continuity meter but you may have to take the armature to a shop for a growler test.
Old 02-07-2019, 11:52 AM   #11
Russ/40
Russ/40's Avatar
Been there done that! Brushes in the wrong holders! I had the same exact problem. Corrected the brush locations, problem solved.
Russ/40 is offline   Reply With Quote
Old 02-07-2019, 06:42 PM   #12
Big hammer
I had mine apart way to many times, I found it wasn't the starter, It Was My Modern Car that I was jump start/ spinning the A starter.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 02-08-2019, 03:46 PM   #13
woofa.express
woofa.express's Avatar
I wrote this in "mini starter" this morning and is quite applicable to this thread. It is copied and pasted. gary.
I had my Tourer (parked behind the ute in the picture below) converted to 12V some time back but not the starter. Each time I cranked I shuddered at the severe impact. I have busted 2 armature shafts so I purchased new field coils. had fitted and started so well. ONCE.
Disassembled and packed the bendix so it wouldn't jam. Again it started so well. ONCE. At present I am awaiting the rebuilding of my starter with a 5/8 shaft and new bendix by the guru Synchro and I reckon he will rebuild like new.
HOWEVER when I purchased the field coil I was unaware of the new light weight starter. I had one demonstrated to me at the Murray Bridge meet and it was a beauty.
From my experience don't mess with your original starter, unless you are a concourse entrant, just buy a light weight.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 03-15-2019, 10:45 AM   #14
Rustyscrap
Solved the slow starter. It was caused by a cold solder job on the soldered brushes. These connections are difficult. Requires a soldering iron of 200 watts. New wires have to be "tinned" properly before connecting to the lugs. Had I to do it over again I wouldn't have even replaced the solder connected brushes. I think proper operation is all about the condition of the commutator.
Old 03-15-2019, 10:56 AM   #15
Anteek29
Anteek29's Avatar
Hooray...thanks for letting us know you fixed the problem!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 03-15-2019, 11:06 AM   #16
Terry, NJ
Terry, NJ's Avatar
Another aspect of this problem may be a poor ground. The best way I know of getting a starter to turn faster is to ground it directly to the battery. The ground path through a lot of old , rusty, riveted joints is not good. Use a modern 12v cable and connect to the same bolt as where the primary ground strap connects. Put a large hole connection (not a battery connecter) the other end. Connect that end to a 3/8 starter bolt and go turn the key and press the starter. It should be able to turn faster and start quicker.
Terry
Terry, NJ is offline   Reply With Quote
Old 03-15-2019, 11:07 AM   #17
Purdy Swoft
Purdy Swoft's Avatar
If the brass-bronze field brushes are so badly worn that they must be replaced , I usually just pick a better core to overhaul . The field brushes usually last a lifetime or more . It is just too easy to ruin a good starter if you don't have the proper tools and experience to replace the field brushes . The ground brushes attach with screws and will usually suffice . The carbon ground brushes are the ones that wear the quickest and most . .
