Old 12-27-2021, 10:10 AM   #1
Smooth_One
Smooth_One's Avatar
Default Fluted reamer for spindle kingpin bushing needed.
Hi all. Hope you guys had a good Christmas.
Anyone in the eastern Michigan area or north of Detroit I 94 area have a reamer I could rent to get my kingpin bushings done?
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 12-27-2021, 10:55 AM   #2
Bob-A
Bob-A's Avatar
Default Re: Fluted reamer for spindle kingpin bushing needed.
I understand an automotive machine shop. Can hone out the kingpin bushings with better tolerances then the reamer. Just a thought.
My last rebuild I used a reamer with good results.
Bob-A
Bob-A is offline   Reply With Quote
Old 12-27-2021, 12:25 PM   #3
Smooth_One
Smooth_One's Avatar
Bob-A
Thanks. My buddy has a small shop but does not have the correct size reamer.
Isaiah B.
Old 12-27-2021, 01:02 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
You buddy does not need a reamer, ...he needs a pin fitting hone such as a Sunnen. I use a 13/16th (0.8125") hone that I can adjust to float the pin. This is a common size used in most automotive machine shops.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-27-2021, 03:59 PM   #5
baba
I am by no means an authority on reamers, but when I did my king pins in my 29 I used bushings and king pins from Snyders along with their reamer. The reamer did not adequately ream out the bushings. Either the reamer was undersized or the king pins were over sized. My local mechanic took the whole works and finally got the bushings reamed. Snyder gave ma a full refund for the reamer. I wish it had worked better. I have since heard of adjustable reamers.
baba is offline   Reply With Quote
Old 12-27-2021, 05:09 PM   #6
rotorwrench
rotorwrench's Avatar
King pins are largely a thing of the past and this sort of puts the reamers in the same category. The better king pin reamers from the era of their use were generally long pilot type reamers that had a smooth transition from the pilot part to the fluted area. The flutes has a spiral cut and had slots cut to allow for a small mount of expansion adjustment of the flutes through a conical expander that was turned at one end. These reamers were available in the 13/16", 7/8", and 15/16" as well as a few other standard king pin sizes. These reamers cut a flawless finish as long as grease was used liberally and the operator was careful about adjustments, cleaning, and use. This is what I use and I set them up for light push fit.
This link is to a set of piston pin reamers that illustrate they type I'm referring to.
https://www.ebay.com/itm/32456210613...UAAOSw-NFgb5qW
Old 12-27-2021, 05:41 PM   #7
Synchro909
Synchro909's Avatar
I have always used an adjustable reamer but on one occasion, the tolerance was a bit tight. The car was almost uncontrollable at any speed. I dismantled everything and used one of the old king pins to burnish them. I was very pleased with the results.
Old 12-27-2021, 06:08 PM   #8
Shampipple
Shampipple's Avatar
Dynamic in Westland just did mine about 3 weeks ago. Wayne Rd and Cherry Hill area.
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird
Shampipple is offline   Reply With Quote
Old 12-27-2021, 06:48 PM   #9
Smooth_One
Smooth_One's Avatar
I looked at this set today already. Thanks for the info!
Isaiah B.
Old 12-27-2021, 07:02 PM   #10
Smooth_One
Smooth_One's Avatar
My buddy just ordered me a 13/16. He owns a machine shop and is not going to charge me for the reamer. Ill see what it looks like
Isaiah B.
Old 12-28-2021, 01:24 AM   #11
BRENT in 10-uh-C
So did he order a 13/16” + 0.001 reamer? If not, you are going to find the finish size of the bushing is going to be 0.0015 too small.
BRENT in 10-uh-C
Old 12-28-2021, 08:01 AM   #12
Smooth_One
Smooth_One's Avatar
Thank you. I’ll check on that!
Isaiah B.
Old 12-28-2021, 08:03 AM   #13
Smooth_One
Smooth_One's Avatar
I’m going to measure the diameter on the kingpins when I get home today.
I’m taking a few family members to Stahls Automotive collection in Chesterfield, mi today.
Isaiah B.
Old 12-28-2021, 01:49 PM   #14
motordr
The work around on that is to wrap a thin shim, .001” or .002” around half of the reamer and run it through again. This will open the bushing up a bit.
motordr is offline   Reply With Quote
