Old 06-19-2018, 07:00 PM   #21
Pete
Pete's Avatar
Default Re: Tachometer for my model A
Originally Posted by Tom Endy View Post
The Westech 6-volt model 2CT32-6V looks interesting. Could some of you who have installed this device post some descriptions on how you mounted it and hooked it up eclectically in a Model A.
Tom Endy
You can see how mine is mounted.
Electrically, the pickup wire goes to the points side of the coil.
The black goes to ground and that is it. Mine has wires for an internal light but I don't use them.
Old 06-19-2018, 07:15 PM   #22
Pete
Pete's Avatar
Originally Posted by 31 Woody View Post
Not trying to be critical or funny, but why would I want a tach in a Model A? I have one in my Mustang Cobra, which does redline at 7,000...been there many times in fact. But the Model A just does not make sense to push and the actual RPMs do not seem important. Is this a curiousity being satisfied?
A tach in a model A is for those of us that have modified engines etc.
Old 06-26-2018, 03:32 PM   #23
Tom Bellfoy
Tom Bellfoy's Avatar
you might want to get on the internet and look up Chinese wholesalers for the digital tachometer/hour meter. Cost is around $14. delivered by mail from yes CHINA, I have one in my coupe and it works very well. my buddy also has one in his model A. no electrical hook up required. just run the one lead to a spark plug and wind it three or four times around the ceramic and you are good to go. When motor is running it reads the RPM (selectable setting for 4-6-8 cyls.) when motor not running it reads hours and can be reset., 6 or 12 volt not necessary.
Tom Bellfoy is offline   Reply With Quote
Old 06-26-2018, 03:50 PM   #24
GRutter
GRutter's Avatar
Does anyone know of a 2" tach that is full sweep and 3000-3500 RPM ?
I don't like the look of the Westach.
GRutter is offline   Reply With Quote
Old 06-26-2018, 06:11 PM   #25
michael a
michael a's Avatar
Thank you for no more than what they cost I'll give it a try
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 06-26-2018, 07:03 PM   #26
Tom Bellfoy
Michael a. :
I purchased a couple about 6 months ago, they have a non-replaceable lithium battery which they say lasts for 2 years. The newer ones apparently have a backlight and the battery is replaceable for a few dollars more
Tom
Old 06-26-2018, 07:23 PM   #27
Y-Blockhead
Y-Blockhead's Avatar
I like the Speedhut tach, it has a 270° sweep, 0-4000 RPM. It is customizable also so you can change the font, color, graphics, etc. to suit you. www.speedhut.com
I should add it is 12v...
Last edited by Y-Blockhead; 06-26-2018 at 07:56 PM. Reason: Add verbage "I should add it is 12v..."
Old 06-26-2018, 10:01 PM   #28
GerryAllen
Woody, I was thinking the same thing. Like someone mentioned earlier, their hearing was OK, why bother with a tac. If I were to spring for a dash mounted gauge it would be a temperature gauge.
Just my thoughts, by the way I am impressed when ever I see a Mustang Cobra, most impressive. With that being said my $ budget is in the Model A range
Gerry Birch Bay Wa
GerryAllen is offline   Reply With Quote
Old 06-26-2018, 10:10 PM   #29
CarlG
CarlG's Avatar
Here's a picture of mine. The Tach is on the left, Water Temp on the right. Both gauges are Autometer, 270 degree sweep, purchased from Amazon. Gauge holder is from Berts. Oh, and they are 12 volt.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-27-2018, 09:54 PM   #30
GRutter
GRutter's Avatar
Thank You. I like the 270 sweep angle. And it's the right size.
Now to make it work on a 6v pos ground system
Old 07-06-2018, 02:00 PM   #31
31 Woody
31 Woody's Avatar
Gerry Birch Bay Wa
I do have an oil gauge and water temp, but not going to put in a tach. The engine is a counter balance pressurized setup, but I am afraid of breaking it. I will leave the high RPMs to the rest of this group! Have fun guys! I do like the looks of that little 4K tach posted above though.
Gerry—you can get used Mustang Cobras pretty cheap. I saw one at Barrett Jackson in January identical to mine but only 4000 miles on it (mine has 10,000) and it sold for $17.5k. Since that sale I have been putting more miles on mine—might as well enjoy it because it isn’t worth much being a low mile 22 year old car.
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
Old 05-23-2020, 09:35 AM   #32
Joe/Ct
Joe/Ct's Avatar
Originally Posted by Davew View Post
I use a "tiny tach". Simple to hook up and works. I have a 6 volt system.
What is a ""tiny tach"???
Joe/Ct
"The older I get, the better I was"
Joe/Ct is offline   Reply With Quote
Old 05-23-2020, 12:32 PM   #33
DENY 411
I have an old analog sears it hooks to the coil and ground. Read the 8 cyl. scale and double it. I am hard of hearing can't tell 450 rpm from 700 rpm !
DENY 411 is offline   Reply With Quote
Old 05-23-2020, 07:04 PM   #34
CWPASADENA
CWPASADENA's Avatar
I have Tiny Tachs. In 2 of my cars. Very easy to install and they work great
Chris W
CWPASADENA is offline   Reply With Quote
Old 05-23-2020, 08:52 PM   #35
Joop
Joop's Avatar
where do you get these. thanks
Joop is offline   Reply With Quote
Old 05-24-2020, 09:31 AM   #36
Nosetime
Nosetime's Avatar
New Westach for sale in Swapmeet forum
Nosetime is offline   Reply With Quote
Old 05-24-2020, 01:54 PM   #37
Joe/Ct
Joe/Ct's Avatar
Chris W
Who did you order these from? What is the part number?
Joe/Ct
Old 05-27-2020, 10:38 PM   #38
Joe/Ct
Joe/Ct's Avatar
Is this the device that you guys are talking about???
https://tinytach.com/gasoline-tinytach
Joe/Ct
Old 05-28-2020, 01:45 PM   #39
Russ B
I have an old Sun Tach and sender for a four cylinder. I found a decent selection on eBay a few years ago. That will give you a traditional look. If it doesn’t work they can be rebuilt. H.A.M.B. has some threads on the subject. I never installed one for my modified banger as I just drive it and shift by how the motor feels to me.
Russ B is offline   Reply With Quote
Old 05-29-2020, 12:40 PM   #40
Joe/Ct
Joe/Ct's Avatar
I just spoke with Steve at the shop and the model number for the Model A Ford, standard ignition (6 v positive ground) is: TT1CRXL.
Joe/Ct
