11-13-2018, 01:16 AM | #1 |
oil lines
Any one know where to get the 3/8 steel tees that some folks use in the lifter galery to route the oil lines to the mains
I just spent hours on the new to no avail Lawrie |
11-13-2018, 07:14 AM | #2 |
Re: oil lines
Aviation supply vendors is where I have seen them. If you cannot find them, consider making them.
11-13-2018, 10:02 AM | #3 |
Re: oil lines
11-13-2018, 12:28 PM | #4 |
Re: oil lines
I just use sweat-on copper fittings.
11-13-2018, 04:40 PM | #5 |
Re: oil lines
Jim, I wanted to use steel ones,not copper.I ,m worried about vibration work hardening the copper.
Katy, I want weld in ones not the hydraulic type, Brent, I will look at an aviation supply co. Thanks Lawrie |
11-13-2018, 04:51 PM | #6 |
Re: oil lines
11-14-2018, 12:41 PM | #7 |
Re: oil lines
Lawrie, long copper lines will crack from vibration but not short, rigid ones or long ones if supported to eliminate movement. I don't think you would have any trouble at all with tees. Many older cars had a small, long copper line to the oil pressure gauge but I never saw one break, doesn't mean they never did, I just never saw a broken one.
11-14-2018, 03:54 PM | #8 |
Re: oil lines
Jim, I will look at the copper ones,
But I have an engine in my shop that has a nice pressure feed setup to the mains and it has the steel tees,I cant ask the owner as he didnt build the engine. Lawrie |
11-14-2018, 07:04 PM | #9 |
Re: oil lines
Swagelok makes all kinds of SS fittings. There should be a local distributor near you.
https://www.swagelok.com/en/catalog/Fittings?gclid=EAIaIQobChMI6JqBlozV3gIVhZ-zCh3FaAv_EAMYASAAEgJv2fD_BwE
AL in NY |
11-14-2018, 07:18 PM | #10 |
Re: oil lines
Swagloc are the screw together type,I need the socket weld fittings,
there will be no room for a screw together fitting. thanks Lawrie |
11-19-2018, 01:06 PM | #11 |
Re: oil lines
Lawrie, If your steel lines will fit snugly into copper tees, you should be able to sweat them together, copper and steel are both compatible with solder.
11-19-2018, 04:36 PM | #12 |
Re: oil lines
Jim
I have had a closer look at the tees in the engine,it looks like they are home made, I have done up a dummy oil line in steel tube and will make my own tees from steel and silver solder them to the 3/8tube. Will post some pics when done. thanks Lawrie |
11-19-2018, 08:50 PM | #13 |
Re: oil lines
Yea, Lawrie that should work just fine.
Brian |
