08-26-2017, 05:03 PM | #1 |
EvapoRust
I found my Model A serial #. Will EvapoRust remove enough rust to be able to read the numbers. I can almost read them but not entirely.
Thanks for your input.
If you see a bomb technician running, do everything in your power to keep up with him. United States Navy |
08-26-2017, 05:22 PM | #2 |
Re: EvapoRust
If the surface is bare metal and not painted, then why not give it a try. If he frame is painted there, then maybe clean well after, sand and paint over with some Rustoleum rusty metal paint afterwards. Maybe sand and paint afterwards regardless. Did you try tracing over it with paper and the side of a pencil lead?
08-26-2017, 05:30 PM | #3 |
Re: EvapoRust
I wouldn't sand it. Clean your frame as much as possible without removing metal around the area where the stars and numbers are suspected. Get some duct tape and tape around the area enough to lay a towel soaked with evaporust and cover it for a few days. You need to let it have some time to work, patience is your best virtue. Use a small stainless wire brush about the size of a toothbrush, I buy a handful everytime I step in Harbor Freight Tools. It might require several brushings and recovering with the evaporust but eventually you will end up with a rust free area.
08-26-2017, 07:48 PM | #4 | |
Re: EvapoRust
08-27-2017, 08:16 PM | #5 |
Re: EvapoRust
I'd suggest a brass brush vs. SS. Softer than the surrounding metal.
08-28-2017, 11:45 AM | #6 |
Re: EvapoRust
08-30-2017, 06:17 AM | #7 |
Re: EvapoRust
Wet your thumb and wipe it over the number. This is what I do on engine and frame numbers.
