Old 01-15-2018, 05:51 PM   #1
d.
Default painting spokes with tire mounted
I just need a color change from bright yellow (wow!) to a nice black for a driver PU. What is a good way to mask the tires to prevent overspray?
thanks guys,
d. is offline   Reply With Quote
Old 01-15-2018, 06:05 PM   #2
zzlegend
zzlegend's Avatar
Default Re: painting spokes with tire mounted
In the past, I have let the air out and collapsed the tire off the bead and lay news paper in the bead area all the way around. Front and rear. Paint and after drying, remove the paper and air them up. Just my 2 1/2 cents
zzlegend is offline   Reply With Quote
Old 01-16-2018, 12:32 AM   #3
3.6rs
3.6rs's Avatar
By the time you do that, you can take of the tyre!
3.6rs is offline   Reply With Quote
Old 01-16-2018, 01:34 AM   #4
DC36
The easiest way I’ve found to paint a rim; get an old deck of cards and place them tucked between the rim and tire one by one and over lapping, all the way around the wheel. Spray paint and move on. It’s really very fast and you can use the cards many times.
DC36 is offline   Reply With Quote
Old 01-16-2018, 06:12 AM   #5
3.6rs
3.6rs's Avatar
Really ?!
Old 01-16-2018, 07:48 AM   #6
marty in Ohio
marty in Ohio's Avatar
I have masked the tire with masking tape and then sprayed. What a waste of time that was! The best, of course, is to dismount the tire but ZZlegend's option works well too. Good luck with the new color.
Marty
marty in Ohio is offline   Reply With Quote
Old 01-16-2018, 08:03 AM   #7
JDupuis
JDupuis's Avatar
DC36: Welcome to the barn. I like your old playing cards idea. May have to try that someday. I have masking taped alot of wheels in the past for quick touch ups. I think the cards would be much faster.
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-16-2018, 08:40 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
This technique works.
Bob Bidonde
Old 01-16-2018, 08:40 AM   #9
Ray64
Ray64's Avatar
Use an old table cloth. Cut a hole one half smaller than rim. Stretch it over rim. Works like a charm
Ray64 is offline   Reply With Quote
Old 01-16-2018, 08:57 AM   #10
willobs
I have brushed Rubbing compound on tires than washed off with water
willobs is offline   Reply With Quote
Old 01-16-2018, 09:01 AM   #11
zzlegend
zzlegend's Avatar
Maybe you should go back and read the posters question.
"Re: painting spokes with tire mounted "
This is why I don't post much any more. Negative attitudes.
Old 01-16-2018, 09:05 AM   #12
KGBnut
KGBnut's Avatar
That card trick sounds pretty good (pun intended). However, I find that with spoked rims you have to shoot the paint from so many different angles to get all the nooks, crannies, inner backs of spokes, etc... that no masking covers everything that is needed. Also, if you are painting over paint, don't you need to get in there and scuff up the old paint?
I find it easier to just unmount the tire...
Good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 01-16-2018, 09:53 AM   #13
ronn
A TRUE CARD SHARK!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-16-2018, 10:19 AM   #14
veggie
veggie's Avatar
Send a message via AIM to veggie Send a message via Yahoo to veggie
Hi D
Isn't that card game BLACKjack???
veggie is offline   Reply With Quote
