Old 05-14-2017, 05:36 AM   #1
Rparker28
Default Corroseal Rust Converter?
All.....new to the forum and the Model A and this is my second thread. My question is that I have a 1929 model a town sedan that is in original condition with some god patina. I found Corroseal and was wondering if that would hurt the originality as far as the patina was concerned? I have attached a photo of the worst side of the car. You paint this stuff on and it turns black and converts the rust to magnetite. I know that the rust needs to go away but is this the way to do it or is there some other way? Ralph
Rparker28 is offline   Reply With Quote
Old 05-14-2017, 08:43 AM   #2
jhowes
Default Re: Corroseal Rust Converter?
I like this stuff but it would seem to me that you can say goodby to the patina if you use it there. I would wax the rust instead. That would hold up as long as I intend to live. Jack
jhowes is offline   Reply With Quote
Old 05-14-2017, 09:05 AM   #3
captndan
captndan's Avatar
A rust 'converter' changes iron oxide into iron sulfate. The rust is hanging onto something so I think the patina is in trouble.
captndan is offline   Reply With Quote
Old 05-14-2017, 09:12 AM   #4
shark 81
shark 81's Avatar
I have used this stuff and it works great! it needs to cure for at least 24 hrs. and, it looks good,the patina looks good but darker only turns the rust to a dark gray and kind off shinny, however you need to topcoat it with in 30 days or it starts to break down. I suppose clear coat would work it is a good primer. I used a color coat . can't tell you how it holds up It has been on my car for about five months still looks good.
shark 81 is offline   Reply With Quote
Old 05-14-2017, 10:10 AM   #5
1crosscut
1crosscut's Avatar
I like to use Johnson's Paste Wax.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-14-2017, 06:40 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
What are those 3 dark spots in the fender and splash apron?
If they are rust holes, I wouldn't worry too much about patina.
I've never seen rust holes like that, so I'm puzzled.
Old 05-14-2017, 09:31 PM   #7
California Travieso
Send a message via Yahoo to California Travieso
Tom,
Congratulations, you made it to 25,000! Get started on your next 25,000
David Serrano
California Travieso is offline   Reply With Quote
Old 05-15-2017, 04:33 AM   #8
Dollar Bill
Dollar Bill's Avatar
Ralph, welcome to the Ford Barn and the best of luck with your project!
Corroseal is a good although expensive product. You can accomplish the same thing with Phosphoric Acid but you do have to keep it dry or reapply it.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 05-15-2017, 04:37 AM   #9
Rparker28
That is where the rust has eaten through. My plans for the car are to get it running and safe and then leave it alone. I just didn't want it to be a car of many colors. I did order the Corroseal and my plans are to at least go over the bad rusty areas with it. The passenger side is the worst part of the car and I will stay in the lines when I put the Corroseal on. Thanks for the responses and I will send a picture after I done this weekend,Ralph
Old 05-15-2017, 06:37 AM   #10
updraught
updraught's Avatar
This might maintain the look
http://www.prweb.com/releases/2014/02/prweb11621575.htm
Patina in a can
http://www.hotrod.com/articles/patina-in-a-can/
updraught is offline   Reply With Quote
Old 05-15-2017, 07:53 AM   #11
captndan
captndan's Avatar
I have used Ospho for years. Please explain what you mean by 'keep it dry'.
Old 05-15-2017, 08:49 AM   #12
Rparker28
Thanks!!!!!!!! I wonder if there is a you-tube video on it? I will absolutely check it out,Ralph
Old 05-15-2017, 09:40 AM   #13
Dollar Bill
Water will wash off a coating of PA and allow it to rust again.
Of course if you apply a top coat of paint following the cure and prep you'll bet good to go.
