06-18-2011, 10:02 AM | #1 |
Front wheel bearing "seal" ?
Hi Guy's,, Does anyone know if a grease seal can be installed in the front hub ? Why was it left out ?.. I wouldn't call the steel baffle a "seal" ... Greg out west, |
06-18-2011, 10:15 AM | #2 |
Re: Front wheel bearing "seal" ?
My thery is that in the era fording a stream was not unusual, the design is such that if water got in it would go out quick, if there was a seal there and no dust cap on the outer end it would retain anything that got inside ---the service interval was short also. --perhaps it was just cheaper to make --there were many other cars made, I just took apart the brakes on a Chrylser ( plymouth, dodge), it has a seal, but how many of them do you see? ---the Mopars also have hydraulic brakes, that didn't make them survive better either.
06-18-2011, 11:29 AM | #3 |
My guess is the way the wheel & hubcap fit the area is pretty well protected. They started using the cap in late 31 about when the spoke drums came out. The area was no longer closed.
06-18-2011, 11:30 PM | #4 |
Thanks for posting this, is that the bearing race you are calling a cap?
Just packed my 30 coupes front bearings and there was no race 31s? that explains it |
06-19-2011, 08:06 AM | #5 |
V4f |
