Old 07-16-2020, 04:13 PM   #1
rehpotsirhcj
rehpotsirhcj's Avatar
Default Door striker pocket/housing
Apologies if this has been asked endlessly...I have as 30 coupe that is missing the b-pillar door striker housing. I tried Snyder’s with no luck. Anyone aware of a source for this?stock or reproduction, no matter.
Thanks,
-Chris
rehpotsirhcj is offline   Reply With Quote
Old 07-16-2020, 07:16 PM   #2
shew01
shew01's Avatar
Default Re: Door striker pocket/housing
Try Bert’s. This vendor sells new and used parts.
https://modelastore.com/
Old 07-16-2020, 08:11 PM   #3
MAG
MAG's Avatar
Had that problem on a 31 slant front door. The housing had broken off (welds). Found it at the bottom of the pillar and welded it back in place. Easy fix.
Will add...before we found it in the pillar we tried to buy one from Berts. Did not have one.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 07-16-2020, 10:14 PM   #4
rehpotsirhcj
Thanks guys. I sent a message to Berts, maybe I’ll get lucky. Mine looks as though it was cut out, so I guess maybe someone else had the same problem a decade ago
I can try the wanted section, just seemed like something that would be repop.
