Old 11-18-2018, 04:43 PM   #1
ericr
ericr's Avatar
Default Has Anyone Tried the Lebarron Bonney Seat Covers?
- or ever made inquiries about them?
If held on by elastic, we all know elastic loses its stretch rather quickly.....
ericr is offline   Reply With Quote
Old 11-18-2018, 05:12 PM   #2
MAG
MAG's Avatar
Default Re: Has Anyone Tried the Lebarron Bonney Seat Covers?
I have installed several LB kits over the past few years. No, they are not held on with elastic. They are top quality and they are not cheap. Look at their WEB site or call them. http://www.lebaronbonney.com
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 11-18-2018, 05:19 PM   #3
Keith True
Keith True's Avatar
Are you talking about their pre-sewn upholstery kits,or the covers made to cover and protect your upholstery?
Keith True is offline   Reply With Quote
Old 11-18-2018, 07:02 PM   #4
Gary WA
Gary WA's Avatar
No Not me!
www.whidbeymodelaclub.com
Old 11-18-2018, 08:37 PM   #5
1930 coupe
Very happy with mine, read the instructions, and watch the videos about 20 times before you start. 1930 coupe seat
1930 coupe is offline   Reply With Quote
Old 11-18-2018, 11:34 PM   #6
whirnot
whirnot's Avatar
My wife and I did our roadster, about 4 years ago, they are top quality, period correct. It is some work, fitting and stretching everything to get it right but a great result. They are held in place by Upholstery (HOG) rings. We did seats, front and rumble, side panels and built in shoulder pads. Also if you want to drift a bit like have a not quite correct pleated front seat, they can do that. Very happy with the kit.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 11-19-2018, 12:01 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Since held in place by elastic straps was mentioned, I'd assume he's asking about slip covers to protect the seat upholstery covers.
Old 11-19-2018, 09:00 AM   #8
jm29henry
jm29henry's Avatar
I like that idea does somebody make that for model a's?
jm29henry is offline   Reply With Quote
Old 11-19-2018, 12:13 PM   #9
California Travieso
Send a message via Yahoo to California Travieso
Apparently, Eric is saying that Labaron Bonney does!
David Serrano
California Travieso is online now   Reply With Quote
Old 11-19-2018, 01:05 PM   #10
Oldbluoval
Oldbluoval's Avatar
Quickly scanned their website and couldn't come up with such.
Oldbluoval is offline   Reply With Quote
Old 11-19-2018, 04:52 PM   #11
Tom Wesenberg
Pillow cases make quick, easy, cheap Tudor seat back covers for the front two buckets.
You could safety pin a pillow case to the bottom cushion.
Old 11-19-2018, 06:12 PM   #12
1931 flamingo
1931 flamingo's Avatar
Mexican blanket.
Paul in CT
Old 11-19-2018, 06:22 PM   #13
ericr
ericr's Avatar
oh it is a cumbersome site to look at, but there is a section devoted to slip covers showing like 4 choices of materials 2 vinyl (pass) and 2 cloth....
Old 11-19-2018, 06:24 PM   #14
ericr
ericr's Avatar
[QUOTE=Keith True;1697434]Are you talking about their pre-sewn upholstery kits,or the covers made to cover and protect your upholstery?
the latter
Old 11-19-2018, 06:50 PM   #15
woofa.express
woofa.express's Avatar
Yes. probably about 1990 for my '28 tourer.
both front and rear seats had a small hole which was there in manufacture. I know this because they had the same vinyl beneath the small holes to hide them. I did not see them for quite a while - they were well camouflaged. I'm too far away to have returned them besides perhaps too much time elapsed.
At the same time I also purchased the hood and sufficient material to make the side curtains. I took them to an antique car upholsterer and he said the hood didn't extend over the sides enough. I asked if he could modify, remember I had material, and he said it was just more simple to make new ones.
I do wonder if I had rejects because I lived on the other side of the world.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 11-19-2018, 07:53 PM   #16
Dick Steinkamp
Dick Steinkamp's Avatar
If you could provide a link to what you are looking at, that would be great. I've searched their site extensively but can't find what you are seeing.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 11-19-2018, 08:15 PM   #17
J Franklin
J Franklin's Avatar
X2 Yes give us the link!
J Franklin is online now   Reply With Quote
Old 11-20-2018, 11:20 AM   #18
jwilliams81
jwilliams81's Avatar
Looks like this is what the OP is referring to:
http://www.lebaronbonney.com/ezb-seat-covers.php
Available in NINE great stitch styles
Choose any material combination
Install directly over your existing seat covers
Easily secure with hog rings
Includes hog rings, pliers and instructions
Starting at just $320 per bench or bucket pair
Matching Door Panel Covering Available!
I have never heard anything about them either. But our cars are listed in their drop downs.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 11-20-2018, 12:09 PM   #19
Dick Steinkamp
Not "slip covers" and not attached with elastic, however.
EZ Boy is just LB's low priced generic looking upholstery.
Old 11-20-2018, 07:27 PM   #20
Brian SATX
Brian SATX's Avatar
Wow, they also have the clear plastic ones to go over your upholstery, just like you used to get from Fingerhut!!
Brian SATX
Brian SATX is offline   Reply With Quote
