Old 09-10-2015, 05:27 PM   #1
30ccpickup
30ccpickup's Avatar
Default Just For Fun During Prohibition
Just for fun, during prohibition, if you were a moonshiner what would you do to your Model A to increase its performance to out run the Feds? (Note: you must use period parts up to 1933). In addition, how would you canceal the alcohol, and is there an "A" model you would prefer? Add why to all above questions?
Pictures of period moonshiner vehicles would be great and links to websites would be informative.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 09-10-2015, 05:44 PM   #2
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: Just For Fun During Prohibition
Don't put it in with the gasoline we're trying to get the dang stuff out the way it is
Jeff/Illinois is offline   Reply With Quote
Old 09-10-2015, 06:37 PM   #3
ericr
ericr's Avatar
Jimmy Durante's '29 Roadster shows his opinion about Prohibition:
https://youtu.be/UWEDF4FdgxQ
ericr is offline   Reply With Quote
Old 09-10-2015, 06:52 PM   #4
ursus
Moonshiners and rumrunners needed a larger vehicle to maximize the volume per trip. My great uncle hauled whiskey from Alberta into Montana many times using a big Oakland sedan with the back seat removed for extra space. I'll bet that an AA truck with the load concealed by hay bales would make a good under-the-radar option to the potential high speed chase scenario.
ursus is online now   Reply With Quote
Old 09-10-2015, 07:52 PM   #5
stillwater
hide a tank in the bed of a pickup and put a cover on it.
stillwater is offline   Reply With Quote
Old 09-10-2015, 11:09 PM   #6
SeaSlugs
SeaSlugs's Avatar
agreed, didnt they commonly transport Canadian whiskey in containers labeled for other stuff like soap and furniture and whatnot?
also if you knew you had to travel thru a known police heavy area if you have a decoy car cause a problem on the other side of town the truck could lumber thru without issue.
that and the age ol trick of knowing the backroads like the back of your hand and cut the lights at night and gun it. kick up as much dust as you can so you cant be followed.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
