04-16-2012, 04:58 PM | #1 |
oilpan capacity
I am sure this has been discussed before, however, I want to relate my expierence. For years I was of the understanding that when changing oil in a Model A one should replace the oil with 4 1/2 quarts of fresh oil. I live atop a steep one mile grade. I have always expierenced siginificant oil dripping from the bottom of the bell housing after the climb to the garage. I recently changed my oil and only put in 4 quarts. I am now happy to find that I have no drips whatsoever after my homeward hill climb. I hope this info helps someone in a similar situation.
04-16-2012, 06:01 PM | #2 |
Re: oilpan capacity
Are you now far below the "F" mark on the dipstick.
04-16-2012, 06:08 PM | #3 |
Re: oilpan capacity
Checking when the dipstick pushed all the way down, it reads oil touching the bottom of the 'F'.
04-16-2012, 06:19 PM | #4 |
Re: oilpan capacity
I would agree I put 4 qts in my coupe and it comes to full. I also find the same with my other vehicles they take less then the recommended. I guess it depends how well you drain the old oil.
04-16-2012, 06:35 PM | #5 |
Re: oilpan capacity
I believe that the dry to full capacity is one imperial gallon (not quite 5 quarts). The drained to full is just over 4 quarts (the rest is in the galleries and drip try)..fwiw,jm
04-16-2012, 08:48 PM | #6 |
Re: oilpan capacity
http://www.model-a-ford-4bangers.com/ |
