Old 05-11-2016, 02:37 PM   #21
Blu Dice
Blu Dice's Avatar
Default Re: After market radios
Will my 6 volt cigar lighter power a 9 volt portable CD/ radio??
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 05-11-2016, 07:06 PM   #22
adileo
adileo's Avatar
Originally Posted by JSeery View Post
Could only wish I was young!!! (or smart!) My four year old great grand daughter can show me things I didn't know how to do!
Adorable js but she has a hammer at the ready. She has everything covered
adileo is offline   Reply With Quote
Old 05-11-2016, 07:31 PM   #23
cas3
blue tooth sounds easy enough, i too am dumb and have a dumb phone to boot. another option i like is the real radio for your car, sent out to one of several places that can do many things to it. some gut it out completely, leaving the face original, and put in modern am/fm, stereo, or a dock for a flash drive to play your favorite stuff. sadly, its not cheap
Old 05-11-2016, 08:52 PM   #24
JSeery
JSeery's Avatar
There are other tools? Who knew? You would not believe the things that kid can do with a cell phone or a tablet, it is like they are born with the knowledge.
Old 05-12-2016, 05:05 AM   #25
dwick01
dwick01's Avatar
Beautiful little one, JS. I too have a 4 year old great granddaughter, and she is the same way with the tablets and electronics. Just amazing.
dwick01 is offline   Reply With Quote
Old 05-12-2016, 06:17 AM   #26
Blu Dice
Blu Dice's Avatar
Gee what happen to MY thread??
Old 05-12-2016, 06:31 AM   #27
Kurt in NJ
Kurt in NJ's Avatar
I don't know how easy it would be to find now, the 60s Blaupunkt am- fm radios mostly could be switched between 6v and 12v, and pos-neg ground, and some have a tape player input that they now use for modern phone- music players, another option is a modern car radio with a remote, hide the radio, power it with 12v jumper box
Old 05-12-2016, 07:10 AM   #28
JSeery
JSeery's Avatar
OP "I'm tired of driving around without music - my '53 is radio delete - still 6 volt - I've read that some guys on here have newer radios with 12 volt batteries for power - can you share how you did this? And how you maintain power to the battery. Thanks"
Are you only interested in 12v installed radio solutions? Only powered by dedicated 12v battery? Or are you open to other approaches? Would you consider a 6v radio?
http://www.classiccarstereos.com/cat...ord-Radio.html
http://www.normansclassicautoradio.c...LIDE_SHOW.html
http://www.bobsradio.com/
This is similar to what Henry was attempting to do to run his breathing equipment. Might review his post on the subject. Think the best approach is two 6v batteries that can be charged by the original generator in the vehicle and then connected to the radio as 12volts.
Old 05-15-2016, 08:04 AM   #29
40ford
40ford's Avatar
Originally Posted by flatheadfan View Post
Simplest and cheapest way is with a 6-12 volt converter. I have a '35 and ' a '36 both are 6 volt systems. I use a 12 volt converter to play a modern 12 volt radio. These converters have been trouble free for years. If you get a chance check this: http://www.ebay.com/itm/Ford-Model-A...tWKXUh&vxp=mtr
Tom
I bought a "modern radio" and the crazy thing has to just about be re-programmed when the switch is turned off and turned back on?I guess it must have power on it all the time so it want lose its mind!Do they make a good simple solid state radio without all the bells and whistles?
40ford is offline   Reply With Quote
Old 05-15-2016, 09:00 AM   #30
wbedwards
wbedwards's Avatar
It should have one wire to keep the memory alive in it with the key off. Read your wiring diagram for it. Leave it hooked to a fused always hot wire. Usually its yellow I believe.
wbedwards is offline   Reply With Quote
Old 05-15-2016, 07:01 PM   #31
40ford
40ford's Avatar
Would this not drain the battery and plus I worry about a short or something and starting a fire?
Old 05-15-2016, 07:46 PM   #32
JSeery
JSeery's Avatar
I wouldn't worry so much about the short (put a fuse in the line) but yes it will drain the battery over time. These radios are designed for cars that are driven daily (or at least frequently).
Old 05-15-2016, 08:23 PM   #33
Kahuna
Kahuna's Avatar
Blu Dice
Does your radio work?
If so there is a thread here about using an Ipod requiring an easy Mod to add the Ipod unit.
I think it'll work fine on 6 volts, if your existing radio still works?
Jim
https://www.fordbarn.com/forum/showth...highlight=Ipod
Kahuna is offline   Reply With Quote
Old 05-16-2016, 05:36 PM   #34
Blu Dice
Blu Dice's Avatar
Car is radio delete. Yesterday I bought a MP3 - well that was a train wreck - wouldn't charge and laptop wouldn't recognize it - so took it back to the store and bought a portable CD/FM player - maybe I can have some rock n roll now.
Old 05-18-2016, 07:18 AM   #35
40ford
40ford's Avatar
I am using a converter 6 volt to 12 volt.How can I make this work?
Old 05-18-2016, 10:08 AM   #36
JSeery
JSeery's Avatar
If you understand that the radio will be pulling some power all the time, it's a small amount, but it is consuming power. Also keep in mind that the 6v to 12v converters can not provide that much power to a radio so you are going to have to keep the speaker power down.
Old 05-18-2016, 12:23 PM   #37
40ford
40ford's Avatar
That is one reason I was wanting to find a radio that did not have all the unnecessary garbage on it.I don't think there is really anything out there that is simple AM/FM.I guess I could use a radio say out of 1970's vehicles?
Old 05-18-2016, 02:05 PM   #38
CaliforniaBorn36
CaliforniaBorn36's Avatar
Maybe something like this, without an electronic tuner or clock?
http://www.amazon.com/Pyle-PLR14MPF-...ords=Pyle+Post
Reviews aren't great, but for a little music it might work. I have looked at this unit and thought maybe... but have not pulled the trigger yet
CaliforniaBorn36 is offline   Reply With Quote
Old 05-19-2016, 08:45 AM   #39
40ford
40ford's Avatar
Save your money!I got one and it is junk!
Old 05-19-2016, 09:46 AM   #40
JSeery
JSeery's Avatar
Some reading on the HAMB if anyone is interested: http://www.jalopyjournal.com/forum/t...-radio.961414/
To me it is a lot easier and cleaner to go with a portable device and wireless speakers.
