02-16-2021, 05:49 PM | #1 |
Edmunds four barrel air cleaner
Back in the day, Did Eddie Edmunds make a four barrel air cleaner(5 1/8") neck? Like the one O'brien truckers and Speedway have. I have Edmunds heads and intake, with a holley 390 carb and thought it would look cool all matching. If so any used ones out there? Thanks
02-17-2021, 02:30 PM | #2 |
Re: Edmunds four barrel air cleaner
I think there are a lot of things currently marketed under the Edmunds name that were not actually available in the old days. That said, if you like it go for it I'm sure it would look good.
02-17-2021, 03:01 PM | #3 |
This on was on eBay a while back>
Edmunds Polished Finish Air Cleaner 4 Barrel Ford Flat Head Hot Rod Rat Rod 1932 This is the one Speedway is offering> https://www.speedwaymotors.com/Edmun...ck,404390.html
02-17-2021, 09:18 PM | #4 |
Petehoovie, Thanks for suggestions,I was not able to find the e-bay ad, must be sold, I will keep looking for others.
02-19-2021, 06:28 PM | #5 |
02-19-2021, 06:44 PM | #6 |
https://www.speedwaymotors.com/the-t...cleaners/28934 |
02-19-2021, 10:12 PM | #7 |
saltracer, Love the video, had not seen it! Thanks
02-20-2021, 01:06 AM | #8 |
I saw a magazine ad today showing Edmunds merchandise. You might try www.OBRIENTRUCKERS.com 508-248-1555
02-20-2021, 09:38 PM | #9 |
They won't fit the older 4 barrels such as the Rochester 4 jet. 5 1/8 is too big.
04-05-2021, 08:02 AM | #10 |
Cal Custom used to make a cast aluminum adapter ring to use a more modern air cleaner on the early 4 barrels, I have one on my 331. I think I've even seen newer plastic versions.
02-20-2021, 09:48 PM | #11 |
Straightpipes, I am using a 390 Holley I think it will fit. Thanks for the update on Rochester carbs.
04-04-2021, 12:45 PM | #12 |
Thats the one
04-05-2021, 09:18 AM | #13 |
I believe it is Mr. Gasket that makes the THIN plastic adapter rings. My experience with them is that they will develop cracks after a year or two of steady use. Also, I was priming the engine and spilled a little fuel on the ring, the engine back fired, and the ring ignited with the fuel and melted.
