02-23-2018, 04:40 PM | #1 |
Ring terminals
I am redoing a wiring harness on my 39 and note the ring terminals all have a rubber hose for insulation. All of my sources of rubber hose are a bit too thick. Anyone come up with a more suitable and original looking hose? (thinner wall)
02-23-2018, 04:50 PM | #2 |
Re: Ring terminals
How about garden drip system hose?
02-23-2018, 04:56 PM | #3 |
Re: Ring terminals
Black shrink sleeving. You can cover with a second layer for a better look. Regards, Kevin.
02-23-2018, 06:18 PM | #4 |
Re: Ring terminals
02-23-2018, 07:12 PM | #5 |
Re: Ring terminals
One of the best things to happen with my wiring is I started buying that shrink tube in 4 foot lengths. Costs way less and I just cut off a hunk whenever I want. I use it all the time.
02-23-2018, 07:39 PM | #6 |
Re: Ring terminals
02-23-2018, 09:00 PM | #7 | |
Re: Ring terminals
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
02-23-2018, 09:04 PM | #8 |
Re: Ring terminals
I frequently have a senior moment and forget to slide the piece of shrink tubing onto the wire before I crimp and solder the connector on. I agree with Kevin ... a second layer makes it look better and if your making a high amperage connection its better protection.
02-23-2018, 09:17 PM | #9 |
Re: Ring terminals
Duplicate post.
02-23-2018, 09:20 PM | #10 | |
Re: Ring terminals
Shrink tubing is one of histories greatest inventions, right after the Thermos Bottle. |
02-24-2018, 02:43 PM | #11 |
Re: Ring terminals
I build motorcycles mostly. A few years ago I bought one that somebody else had built. A good deal on a real pretty bike. One day I realized that there was not one single blue or yello or red terminal mashed insulator on the whole machine. I still use a few, but they are hidden. My napa now has some of the non insulated terminals, but I still have to cut the plastic off butt splices, etc.
02-24-2018, 03:16 PM | #12 |
Re: Ring terminals
Thanks guys. I am gonna keep looking. Shrink tube is just not the same regardless of how many layers. I`ll report back if I find a good replacement.
Finding clear tube is easy but the black seems to be the problem. Wife works at hospital and brings some outdated tube home occasionally and it is close in size but again usually clear. Thanks |
02-24-2018, 05:05 PM | #13 |
Re: Ring terminals
They do make Thick Walled Heat Shrink Tubing
See > https://www.ebay.com/sch/items/?_nkw...ds=&rmvSB=true And > https://buyheatshrink.com/heatshrink...polyolefin.php
02-24-2018, 05:47 PM | #14 |
Re: Ring terminals
Try Rhode Island Wire. Lots of good stuff!!
02-24-2018, 09:37 PM | #15 |
Re: Ring terminals
Rhode Island Wiring sells the tubing in any length you want to buy. It is correct and if you choose, you may put shrink tubing under it to get a double insulation.
02-24-2018, 10:52 PM | #16 |
Re: Ring terminals
Shrink tubing is great stuff. I've spent the weekend making a wiring harness for the turn signals I'm installing. I used a few different sizes and bought it by the metre length as its cheap that way. The left overs will last me the rest of my life.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
02-25-2018, 04:04 AM | #17 |
Re: Ring terminals
I'm doing the same myself, a complete new loom for my 41 pu. Ununsulated terminals, and heat shrink when I can. It may not be perfectly as original, but it is functional and smart and looks professional. It's worth getting a good pair of crimpers. I am also using the braided polyester sleeving. It takes a bit of planning if the loom is not dead simple, but I am pleased with my efforts.
In my mind, I wouldn't mind betting the original rubber tubing insulating material required an expander tool. I'm thinking a three pronged tool that expanded the tube to slip over the terminal and is then released and withdrawn. Pure guesswork, but these were mass produced oem harnesses and special tooling would not have been an issue. I don't know what would have been available to the home gamer back in the 30s and 40s. Mart. |
02-25-2018, 07:15 AM | #18 |
Re: Ring terminals
There is a tool with 3 metal rods expanding to put the numbered sleeves on industrial wiring that is still sold...may work for this.
02-25-2018, 08:39 AM | #19 |
Re: Ring terminals
For those of us who sometimes miss a step, only to realize it later, there is heat shrink tape (Amazon: 1" x 180' for $7.85) and liquid electrical tape (Amazon: 4 oz bottle for $6.76). I have used both over the years with varying success. One reviewer posted detailed instructions for the tape. Neither is as neat as heat shrink tubing.
02-25-2018, 10:07 AM | #20 |
Re: Ring terminals
I agree with "Mart" about getting a good crimper. Those flat, black things with the red handles that most of us have are crap. I got a good one from Amazon.com for about $30 that works much better. Also we've heard the saying "Jack of all trades, master of none". I feel this way about electrical tools. I used to use one of those flat black things that was supposed to be a wire cutter and stripper as well as a crimper. These days, I use my new crimper, a quality set of side-cutters, and a purpose made stripper and it has made my wiring tasks much easier. The big advantage though, is my connections are of much higher quality that they used to be.
