Old 06-11-2022, 04:51 PM   #1
sphooch
sphooch's Avatar
Default A gallops no more
got it running good thanks for the input guys. so i changed out the main jet, measures 1.48 in., then i blew out the carb with air,then i changed the carb. bowel gasket they are suppose to measure .048 in. mine was .023 ?? brand new . so with just these minor changes ,I set the idle opened the air adj. 1& 3/4 turns . the gav now works . i took it for a short ride and i think its running good.new wwtires and painted rims. I'm READY. THE HOOCH
sphooch is offline   Reply With Quote
Old 06-11-2022, 05:42 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: A gallops no more
My Ford Model A Roadster - sphooch
Old 06-11-2022, 06:07 PM   #3
nkaminar
nkaminar's Avatar
Nice looking car.
Old 06-11-2022, 07:21 PM   #4
Gary WA
Gary WA's Avatar
Great thanks for the update! Nice Model A
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 06-11-2022, 11:47 PM   #5
jeepguy1948
Do you know what the main jet you took out measured?
jeepguy1948 is offline   Reply With Quote
Old 06-12-2022, 07:31 AM   #6
sphooch
sphooch's Avatar
the main jet i took out was only 1/32 in. short of the recommended.
Old 06-12-2022, 10:03 AM   #7
katy
katy's Avatar
Deleted
Old 06-12-2022, 10:36 AM   #8
Gary WA
Gary WA's Avatar
should be 1 15/32, cap jet 1 5/32; the main jet should be level with top of the ridge where the venturi sets in the carb.
Old 06-12-2022, 10:40 AM   #9
Gary WA
Gary WA's Avatar
I would say when you blew out the carb you probably got ride of misc debris in other areas of carb, the gasket thickness ? you talking the one between the 2 halves/?
Old 06-12-2022, 12:25 PM   #10
ETAModel
That's a great looking Roadster. Glad you got the gallops out.
ETAModel is offline   Reply With Quote
Old 06-12-2022, 12:37 PM   #11
Cape Codder
Cape Codder's Avatar
Sooo......how many GALLOPS does it take to make 1 HP?
Cape Codder is offline   Reply With Quote
