Old 11-17-2012, 06:00 PM   #1
19Fordy
19Fordy's Avatar
Default How do I remove this heater switch knob?
I think it's for a 1947 Ford. I would like to remove just the plastic knob so I can unscrew it from the mounting plate. I
don't want to experiment and break something. Thanks.
Old 11-17-2012, 06:13 PM   #2
Rustyspokes
Rustyspokes's Avatar
Default Re: How do I remove this heater switch knob?
I believe the knob just pulls straight off, there is a small groove in the metal shaft that aligns the knob so that it can be put back on the same position for the different speeds , also should be a small bulb in the metal shaft. my experience was this on mine .. the other hole in the mounting plate if for the Defrost pull sw.
Rustyspokes is offline   Reply With Quote
Old 11-17-2012, 06:16 PM   #3
Henry/Kokomo
Henry/Kokomo's Avatar
Rustyspokes X 2. Pull the knob off. Remove the bulb. Un-screw the lock nut. Same setup as on my '46. Bulb should light when heater is "on". Good luck.
Henry/Kokomo is offline   Reply With Quote
Old 11-17-2012, 06:17 PM   #4
19Fordy
19Fordy's Avatar
I tried pulling it straight off, but no luck. I sprayed it with WD 40- and will let it set for a while.
Old 11-18-2012, 03:40 PM   #5
19Fordy
19Fordy's Avatar
I was finally able to remove the plastic knob using a brake spoon as a pry tool. Perhaps this will help others also. Thanks to all for the help.
Old 02-09-2020, 10:10 AM   #6
ravedodger
I struggled with this last night and a few minutes this morning. The brake tool helped tremendously! Thanks guys!
ravedodger is offline   Reply With Quote
Old 02-09-2020, 11:05 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Just a tip, any of these push on type knobs etc. I have removed, I lightly coated the mating surfaces with Di-electric grease before reassembly. (makes any future removal easier)
