08-17-2019, 12:58 PM | #1 |
How does a DMV registration number come from?
Hallo, I have a difficult question: My car has in the Germanized registration certificate a five-digit DMV no. from California. As a justification for a DMV number instead of the VIN number I was told that DMV takes over the engine number if the original VIN number is no longer available.
If so, the DMV number would have to match the engine number. Then my roadster would be from Feb. 1928. But the engine number is seven digits, which would be from May 1929. The car is 1928 registered. If it is true that DMV takes over the number of each built-in engine, would that mean that in the DMV registration an engine of 2/28 was installed, and later a motor of 5/29 was changed? Or does a DMV number have an other origin? Thank you for all help with my history exploration!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
08-17-2019, 02:19 PM | #2 |
Re: How does a DMV registration number come from?
The DMV number is sequntially assigned and does not relate to the original engine number. Here is mine (with the last three numbers blanked out). The original number appears, if readable, on the left frame rail just under the cowl, the body must be lifted to see it. For years these cars were registered by engine number but as far back as 1971(when I registered my RDPU) the DMV began assigning their own number as it was common to replace the engine. I assume you are finding that number on a plate riveted to the door jam but you will probably also find that number on a plate attached to the vehicles frame.
Charlie Stephens Last edited by Charlie Stephens; 08-17-2019 at 02:28 PM. |
08-17-2019, 05:25 PM | #3 |
The DMV assigns a number when the owner is too lazy to expose the number on the frame for verification.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
08-17-2019, 08:45 PM | #4 | |
Charlie Stephens |
08-17-2019, 09:13 PM | #5 |
I've been wire wheeling that section of the frame and haven't found a trace of any numbers. There is a lot of pitting there though...
08-17-2019, 09:38 PM | #6 | |
Charlie Stephens |
08-17-2019, 09:47 PM | #7 |
Clean the area on the frame where the number should be to bare metal. Build a silicone dam around that area. Put Mauriac acid in the dam and let it bubble for a while. Remove the acid and let it dry. Looking carefully in good light the numbers should appear darker than the surrounding metal.
08-18-2019, 05:23 AM | #8 |
Hallo Charlie, thank you for your comments. I understand that the DMV number is unrelated to the assembly time of the car. That's a shame because I can not find any further history now.
But good to know how a DMV number came about. Thank you!
08-18-2019, 08:38 AM | #9 | |
Charlie Stephens |
08-18-2019, 08:39 AM | #10 |
Werner, the DMV number problem is what the State of California issues. Other states in the USA have different procedures and California's laws are not used in other states. Most of the above posters are from California and they have to follow those rules.
Ford made the engines in a separate plant from the frames. The engines were stamped with a number at the plant. They were sent to the assembly plant and when the engine was installed on the frame, the frame was stamped with the same number. in the Ford Owners Manual it states that the engine number becomes the serial number of the car. I would say ignore the DMV number and go with the engine number when you register the car in Germany. If you can find the frame number it may not be the same as the engine number due to an engine replacement in the past. If you have documentation from your seller that has the engine number as the number of the car, go by that. |
