Old 09-04-2020, 08:03 PM   #1
Blastfromthepast
Default 1936 LB engine fuel pump stand to intake
I need someone who knows this Flathead really well.
My question is when you remove the fuel pump stand from the intake you find
A gasket and a push rod. Remove the gasket and Around the push rod is a metal sleeve that has sort of a cut out notch like its cut I half. Does the cut out notch face rear or front of the engine When being replaced back in and does it matter.
Blastfromthepast is offline   Reply With Quote
Old 09-04-2020, 11:52 PM   #2
Brian
Brian's Avatar
Default Re: 1936 LB engine fuel pump stand to intake
Actually, there are several 'cut out notches' in that tube. they are baffles. Fit the tube in any orientation; it doesn't matter.
Old 09-05-2020, 06:55 AM   #3
Terry,OH
Terry,OH's Avatar
Ford used the oil baffle tube from 35 till 48. I have never seen a document to insert the tube in any specific direction, for these years, nor is it marked such.
Old 09-05-2020, 07:19 PM   #4
Blastfromthepast
Thanks fellas for your quick response.
I just didn’t want to mess things up with the installation
Thanks again, Blast.
